Old 10-22-2017, 10:06 PM   #11
Eman
Liked 133 Times in 76 Posts
Default Re: Brakes Fix
If your ratio is 7:1 and you reduce it to 6:1 you will have less leverage therefore less multiplied force resulting in lower brake pressure.
Old 10-22-2017, 11:41 PM   #12
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Sorry i had it backwards. Thank you for the correction. It is what i meant.
chris ok is offline   Reply With Quote
Old 10-23-2017, 02:18 AM   #13
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Originally Posted by Coleydog View Post
How well does it stop at speed? Does it pull or try to lock up the rears?
Mike
I didn't notice anything other than holding it on the line. I'm not normally a finish line braker. I only ran it 11 passes after swapping the lines.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
