Old 05-16-2017, 10:28 AM   #11
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
Default Re: new combo missing a bunch of power?
convertor....nothing will make a turd out of a stout combo like the wrong or damaged convertor can.
just a guess.... but what worked before is not getting it near the powerband now
Bill Diehl B200 C/D STK
Bill Diehl is offline   Reply With Quote
Old 05-16-2017, 11:03 AM   #12
pfordamx
Liked 7 Times in 5 Posts
the car runs on e85 the carb was built for this combo. not saying its perfect but hopefully better than a coffee can purring gas down the intake.
pfordamx is offline   Reply With Quote
Old 05-16-2017, 11:38 AM   #13
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
This sounds so obvious that I hesitate to post it......
Have you rechecked your cam timing?????
Bob Mulry 7516 STK
A & M Motorsports
Old 05-16-2017, 11:51 AM   #14
pfordamx
We have discussed cam timing. haven't checked it yet its on the list of things to go over this weekend.
Old 05-16-2017, 12:00 PM   #15
Liked 5,129 Times in 1,956 Posts
Not the converter.
With NO stator ,it would run about 12.0h @ about 125 !
Put it in manual 3rd gear, and flash the converter.Not going to hurt anything at that power level.
Old 05-16-2017, 12:03 PM   #16
At least a tooth off then.
Old 05-16-2017, 01:58 PM   #17
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
I think a big cam a tooth off would cause the valves to hit the pistons.
Paul Precht is online now   Reply With Quote
Old 05-16-2017, 02:00 PM   #18
Paul Precht
Back in the early 70s I broke a B + M convertor and my Cuda lost about 3 tenths, it wouldn't stall much past idle.
Old 05-16-2017, 02:01 PM   #19
Maybe, but this a bracket motor.
Maybe they already hit?
Old 05-16-2017, 02:21 PM   #20
pfordamx
i can check stall on the transbrake right? and i can tell you it will go to 4500 easily on the brake because thats where the 2 step is but it drops a ton of rpm inbetween gears. could line pressure or trans being over full cause this type of issue? the fact that it still leaves is what makes me think the sprag is ok. i was considering raising the 2 step to 6500 and seeing where the converter stopped it. could a bad msd box cause this type of problem? the only things that aren't new are the box and plug wires. so they're pretested but 6-7 years old when everything else is relatively new.
