08-21-2007, 11:29 AM | #11 | |
Liked 2 Times in 1 Post
Re: Modified questions
I think the N351 head would be very good for a class requiring cast iron, it doesn't show the flow numbers of some other heads but makes horsepower beyond the flow numbers. In classes using aluminum heads the Z304 can make some good HP. |
08-22-2007, 08:48 AM | #12 |
Liked 282 Times in 152 Posts
The V head if Im not mistaken is AL while the N head is cast iron----Also the V head is made for Ford BY EDELBROCK it is part of their Victor series of heads--- Kinda hush hush on the specs but they do move a lot of air and will really pick up an engine HP wise--For furthur info/ordering/availability etc call RDI@ 888-360-7223----------Comp 387
08-22-2007, 10:35 PM | #13 |
Liked 32 Times in 14 Posts
Yeah, I called Ford "Race Parts" and talked to a real pleasant fellow, not. Anyway, this guy would just about tell me nothing about the V351 heads except that they were of a "proprietery" design. He said they were a 15* valve angle, 47 cc chamber, and the ports are unfinished. He said that a pair done "correctly" would flow as good as Yates heads. As I have worked on some used Nascar Yates heads for some of my customers I asked him for a idea of what kind of flow numbers he was referencing because the Yates heads can flow dramatically different depending on which style you have. He acted like I had insulted him and said that would depend on who ported them. Duh. I asked him if they were like the Edelbrock Victor "Pro Port" heads and all he said was I could get all the parts for the heads from Jesel and thanks for calling. Click. What a jackass. So, I guess at this point if I decide to use aluminum heads I will probably go with the better flowing Yates stuff. The iron N351's are definately a good head for iron though and that may be the smarter combination, and slightly less expensive. I fully understand flow numbers are not the most important quality in a head but it does give a reference to go with. So, what kind of flow numbers has anyone seen from a set of ported N351's? Thanks for the interest.
Jay
Jay Roeder facebook.com/racefuelsales Former N/SA , Soon to be SS/AS, Renegade Race Fuel dealer |
11-03-2007, 08:28 PM | #14 |
Hi fellas, me again! I am still knocking around this Modified plan and I have a question I'm hoping someone can/will answer. I am thinking about running in SS/CS which as discussed earlier is a cast iron head class. This leaves me with only one head choice,the N351. Just to make sure we are on the same page, I am an engine builder and I do have a flow bench,(dry flow), but as for knowing what I'm up against in this class I have not much of a clue other than it costs alot of money to be fast. My first question is, keeping in mind that I realize the flow numbers are not always the answer, if I could get a N351 head to flow somewhere around 310cfm Intake@.800" and 240cfm exhaust @.800" WITH a good fat curve on the way up will I even be close to the GM and Mopar heads? I realize this is a general question about head flow but at this point it is the only way I know of to get any idea of what I would be up against. I have no illusions at this point of being a "killer" in the class but I also have better things to do than bring the proverbial "knife to a gunfight". Any advice is appreciated as always.
Thanks, Jay Roeder
11-03-2007, 09:20 PM | #15 |
n351
11-09-2007, 10:39 PM | #16 |
Liked 28 Times in 1 Post
I run the N351 in ss/cs. There are 2 other fords in the class, Venice Perno with a Thunderbird and Jamie Groves with a Maverick they are both from Ontario, Canada. I run out of Div 4. You can be competitive with that head. The class is dominated by David Bogner (Mopar) and Michael Mans (Chevrolet) and the record is a 9.37. All of the Fords have been in the 9.90's. Most of the ford guys will give you any help you need and we would love to see another ford in the class. e-mail me ashmig@verizon.net Ashton Hudson SS/CS 373
12-05-2007, 11:22 PM | #17 |
Jay,
I will be running a SS/CS 67' Nova next season and the cast iron bowtie heads on my engine flow about 295 cfm. Pat Hennebery Jr. |
12-09-2007, 11:53 PM | #18 |
01-24-2009, 03:36 PM | #19 | |
01-24-2009, 06:47 PM | #20 |
Liked 683 Times in 292 Posts
