Old 03-21-2015, 10:04 PM   #1
Ed Wright
Ed Wright's Avatar
Default Re: trans cooler
Originally Posted by ATI Performance Products View Post
We run one on the Challenger since the 904 is small and light with all aluminum parts. I don't need it at the races (except when I went a few rounds in a row at some shortened races) but when we are testing the Challenger can run 5+ passes in a row, and the trans will get to 200+. The Super F Synthetic fluid over Conventional Type F gets us that far as with regular non synthetic it was 200 after 3 passes. I have the cooler mounted under the car, facing the ground and it has a fan on it. Its the Derale "atomic" cool that we stock.
I don't have a cooler in the COPO since we can't cool the engine and blower off fast enough to worry about it, and its a T400 with more capacity.
You can be bybassed in the pump and just plug holes as mentioned or loop the lines. I keep a loop on the COPO so I can monitor cooler pressure.
I use your converter. What are your thoughts on synthetic Trans fluid?
Ed Wright 4156 SS/JA
Old 03-22-2015, 12:38 AM   #2
Liked 1,789 Times in 408 Posts
Ed, ATI has their own synthetic fluid. Jim has been after me to try some, I've been testing other stuff, I can't give it an honest fair back to back test.
Old 03-22-2015, 12:51 AM   #3
Liked 5,114 Times in 1,948 Posts
The way I look at this is from my own personal experience.
If you don't plan on going quick, back to back late rounds, either in S/SS or bracket racing, then you probably won't need an auxiliary trans cooler.
Old 03-22-2015, 08:22 AM   #4
Dragsinger
Liked 99 Times in 60 Posts
Mark, I like your comment and agree. I see no down side to running a cooler and you point out one very positive advantage.
Larry Woodfin 471W
