Go Back   CLASS RACER FORUM > Class Racer Forums > Factory Stock and Super Stock
Old 01-24-2015, 08:57 PM   #1
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
Default Boost Monitoring?
I was reading a story about how the rules are enforced in the British Touring Car Championship. As road racers go, this is a relatively low budget class. Front wheel drive cars with factory turbo-charged 4 cyl engines, with rules similar to stock eliminator.
The sanction provides a boost sensor that is compatible with the mandated data logger. The log is reviewed to make sure the maximum allowable boost was not exceeded, except in cases of missed shifts, early downshifts, or brief over-revving.
I wonder if this would be needed or wanted in Factory Stock for supercharged applications? As it stands now, boost is teched by measuring pulleys. Is that enough? Is there a waste gate on any of these? Wouldn't modified rotors/screws give a clever competitor an advantage? The logger would eliminate the need to disassemble the blower to detect a car with more boost than the others.
I don't think anyone that owns a CJ, COPO or Drag Pak would see a mandated data logger as a financial burden. I think they have a Racepak logger as standard equipment anyway.
The old front wheel drive cars just tighten up the waste gate when they need more boost. But if they get carried away, they'll blow up the engine. Is that good enough for the factory race cars too?
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 01-24-2015, 10:13 PM   #2
GUMP
Default Re: Boost Monitoring?
Gotta love statements like this........
GUMP is online now   Reply With Quote
Old 01-25-2015, 08:56 AM   #3
Tony Curcio
Serious question: don't you already have a data logger? Isn't it a Racepak?
All that needs to be done is to install a boost sensor and connect it to the V-Net. The sensors are held by the sanction between events to minimize tampering.
Old 01-25-2015, 05:57 PM   #4
Tony Corley
Liked 61 Times in 25 Posts
Why monitor it? If a competitor figures out a way to produce more boost using components that are deemed legal, I don't see that it's any different than a competitor that discovers a better valve job, cam profile, etc that produces more hp. What about the guy that figure out how to increase engine rpm ? (produces more boost). I'm not trying to start an argument, just saying that with a turbo/supercharger combination, boost should be as important part of performance/tuning as any other part of the car.
Tony Corley is offline   Reply With Quote
Old 01-26-2015, 07:48 AM   #5
Tony Curcio
That's the right question. At least one competitor was disqualified last year for having the wrong size pulley. Why? Because changing the pulley changes the boost.
So, is increasing the boost against the rules, or isn't it? If the answer is yes, then face reality- there are other ways to do it.
Old 01-26-2015, 09:38 AM   #6
Tony Corley
I don't think they are limiting boost, just the way that you make it. Changing pullies should be illegal, same as running a cam over the specified lift is. But just like a cam rule, it's what you can do in between all the variables makes the difference. Any blower is going to have a limit of what it can produce, and specifying pulley size helps limit it. For the record. I have not raced Stock. but have a lot of experience with a power adder class that used to exist with a another sanctioning body that had very strict rules, similar to stock. Pully size was specified, so then it becomes a matter of reducing restriction, (porting was not allowed), and increasing rpm's.No different really than a naturally aspirated engine.
