Old 09-23-2014, 01:25 PM   #11
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default Re: Need a-arm front suspension help/suggestions after near
I used these Moog offset control arm shafts and Energy Suspension urethane bushings. They have a large diameter stud and lock nut in place of the small factory bolt.
[/URL] Global West makes a great setup and Afco has greaseable steel control arm bushings.
Alan,
Which part number did you use? K5250? Jegs is not model specific enough to be certain.
Thanks
Clark
Old 09-23-2014, 04:31 PM   #12
Alan Nyhus
Liked 800 Times in 237 Posts
Originally Posted by cad View Post
Alan,
Thanks
Clark
Yes, pn# K5250. -Al
"That'll never work....."
Old 09-24-2014, 11:25 AM   #13
Run to Rund
Liked 56 Times in 29 Posts
Some upper A arms use grade 8, 3/8" fine thread bolts at the ends of the shafts. Others have longer shafts with big nuts on the ends. If header clearance allows, you could use them instead.
Old 09-24-2014, 01:08 PM   #14
FLEMING
Liked 55 Times in 26 Posts
I redid the front end of my 74 nova last spring and used the afco bushings moog offset top shafts and long ball joints.. made a HUGE difference in my car.. It is so smooth now and drives much better... Would do it again in a heartbeat..
FLEMING is offline   Reply With Quote
