Old 09-01-2013, 11:02 AM   #11
scott smith
Liked 13 Times in 3 Posts
Default Re: Ford Maverick combo
I own a 71 comet gt 302 2bbl auto why is hp factor different from 72 cannot see the diff in the specs am i missing something?
scott smith is offline   Reply With Quote
Old 09-01-2013, 01:54 PM   #12
partsbob67
Liked 79 Times in 11 Posts
1972 was the year the factories changed the way hp was figured. on the up side 71 and 72 comet are the same visually.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 09-08-2013, 11:41 AM   #13
scott smith
does this mean i could run the car as a 72 with the 71 block and heads or would i need a 72 engine ?
Old 09-08-2013, 02:01 PM   #14
Joe Toller
Liked 4 Times in 4 Posts
Just check the engine specs on www.nhraracer.com. It will tell you what heads, carb, and intake, as well as piston and cam specs.
Old 09-08-2013, 06:09 PM   #15
scott smith
thank you
Old 09-09-2013, 08:09 PM   #16
partsbob67
rule book states that you have to run the same year block or use an "approved' block. kinda depends on how close you follow the rules.
bob beals 7244
Old 09-09-2013, 08:22 PM   #17
Jeff Lee
Jeff Lee's Avatar
Nowhere does it say this!
Jeff Lee 7494 D/S '70 AMX
Old 09-10-2013, 09:36 PM   #18
partsbob67
Must be same year and make as car used, aftermarket NHRA- accepted cylinder blocks permitted. section 10a page 3 in the stock section.
bob beals 7244
Old 09-12-2013, 04:20 PM   #19
michael mercer
Liked 2 Times in 2 Posts
The 71 & 72 302's have the same block, heads, cam, and intake.
The numbers on the carbs are different.
michael mercer is offline   Reply With Quote
Old 09-12-2013, 06:00 PM   #20
scott smith
thanks mike thats what i needed to know.
