Old 01-06-2013, 05:54 PM   #11
Joe Abbazia
Liked 19 Times in 4 Posts
Default Re: Need Gear Recommendation
look under the hood not the rear.
Joe Abbazia is offline   Reply With Quote
Old 01-06-2013, 05:56 PM   #12
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
shifting @ 7k
Is this where the shift light is set, where you're pulling the shifter, or when the transmission actually engages? These are three different times/rpms.
I leave with my hand on the steering wheel, and by the time I react to the shift light, reach the shifter, slap, and the trans hits 2nd, it can be 700 rpm past the shift light rpm setting. High gear is far less of a difference, but that 1-2 shift is critical. I use an Auto Meter Ultimate Playback tach, and offset my shift light(s) accordingly. This should be basic stuff, but I've met some people that have raced for a very long time that had no idea where they were *actually* shifting.
I agree with others that much of the ET you're looking for is in the first 60'.
Old 01-06-2013, 05:57 PM   #13
Lonnie Cox
Originally Posted by Lonnie Cox View Post
converter is ATI 8inch Treemaster Salesman Charlie Plott
The 2 step was not hooked up, seems to do better when I flashed @ about 2800
What about my tire the roll out is 96 inch
Lonnie Cox is offline   Reply With Quote
Old 01-06-2013, 06:25 PM   #14
Joe Marcinowski
Joe Marcinowski's Avatar
Liked 33 Times in 15 Posts
Try some 92.5 radials.
Joe Marcinowski 3377 STK
Joe Marcinowski is offline   Reply With Quote
Old 01-06-2013, 06:48 PM   #15
Greg its is a 350 cid the class is I/SA 12.30 index,
At that weight, you really need the 5.38.
What does the converter actually flash to?
Old 01-06-2013, 07:17 PM   #16
Billy Nees
Liked 7,779 Times in 1,742 Posts
Alan, not dissing anyone here but most people don't know what their flash rpm is or how to find it out.
Trans in high gear, slow roll, mat the throttle and see what rpm the tach goes to. That is your flash rpm. Not to be confused with stall speed.
Billy Nees 1188 STK, SS
Old 01-06-2013, 07:26 PM   #17
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I agree with Joe...
You have a good converter and the gearing is not that far off..
60 foot time is pretty slow....and RPM at the finishline is low....as is your MPH, and gearing it up is not going to help....
Either your motor is pretty weak or it is not tuned right....
Rich Biebel
S/C 1479
Stock 147R
Old 01-06-2013, 09:20 PM   #18
Monte Howard
Monte Howard's Avatar
Liked 71 Times in 23 Posts
Gearing is fine, they are right, you need more HP. Look at you r chassis and make sure everything is moving freely. I found 3 tenths in the chassis on my stocker.
But I think you really need some Hp.
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
Old 01-06-2013, 09:30 PM   #19
rod butcher
Liked 132 Times in 27 Posts
I don't think you need a gear change. You are down on power and/or have a major tuning issue.
rod butcher is offline   Reply With Quote
Old 01-06-2013, 09:54 PM   #20
Originally Posted by Myron Piatek View Post
Carb tuning is a big factor as well!
That was going to be my point too, Myron... after I asked about the total timing, and where the cam is in at.
