#11 |
Liked 520 Times in 132 Posts
Thats it. Although I need a tenth! LOL
#12 |
If we designed a CFD base specifically for the 4GC, would you be able to use it?
#13 |
Liked 33 Times in 11 Posts
2013 rule book, section 11A, page 2
Air-cleaner base may be cut or trimmed, but welding, bolting, riveting, epoxying, or any other form of fabrication prohibited. |
#14 | |
If that's the case then alot of air cleaners I've seen need to go in the trash.
#15 |
If it can be used, I'll utilize the CFD programs and design a 4GC base prototype that can be dyno/track tested next week.
#16 |
My guess would be that if it did not come on that particular combo or carb than your not suppose to use it.
4878 SS/GA 66CHEVY II |
#17 |
Liked 333 Times in 180 Posts
I have several NEW bases and adaptors to make this type of set up almost the exact thing in the picture---$40 shipped UPS to your door-- let me know by PM please if anyone has interest in them--- you will have to fabricate the attaching rods to hold the base in place but that should'nt be a problem---we made one up in less than an hour
#18 |
Liked 54 Times in 27 Posts
The written rule does not specifically exclude an adapter that is simply sandwiched between the air horn and the air cleaner base. For example, Caddy Sevilles, etc. used a riser type adapter, although it did not change the mounting diameter. Now you just need to get NHRA to follow your logic. . .
#19 |
anyone have one of these for a rochester?? I would like to have one.
#20 |
Liked 129 Times in 59 Posts
Late 70's/early 80's small block Chevy pick-ups used an adapter/spacer ring right below the air cleaner base. It was about 3 inches high with a tube for a crankcase vent hose. That would lift things up, but then hood clearance might be an issue.
Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
