Old 07-29-2012, 01:35 PM   #11
Keith 944
Keith 944's Avatar
Default Re: carb help, Holley dbl pump.
ok, i found whats up, left bowls full last night. today front is empty. now i know where to look. more later....
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 07-29-2012, 02:18 PM   #12
Ed Wright
Ed Wright's Avatar
If the front throttle blades don't get wet when it sits the primary power valve gasket is leaking.
Ed Wright 4156 SS/JA
Old 07-29-2012, 03:35 PM   #13
jmarkaudio
I've seen some less than stellar PV gaskets lately, the best ones out there now are some red ones from Quick Fuel. It's the same material they use on their new float bowl and metering block gasket. There used to be some really good blue teflon coated ones, I wish I knew where they came from.
jmarkaudio is offline   Reply With Quote
Old 07-29-2012, 06:29 PM   #14
NORMAN BARNARD
Liked 2 Times in 2 Posts
Jmarkaudio......try braswell carburetors in tucson, az. Part number for teflon coated p/v gasket is 082501..........norm
NORMAN BARNARD is offline   Reply With Quote
Old 07-30-2012, 04:33 PM   #15
Keith 944
Keith 944's Avatar
looks like I'm going to have to remove it and look more. i took the metering plate off, changed pv. gasket, metering block gasket. same leak, (takes about 10 min to see a measurable diff). took apart again, grinded pv plug, flipped gasket, tried again. same leak. seems to be low on the throttle blade area....
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 07-30-2012, 05:34 PM   #16
BlueOval Ralph
Banned
Put new bowl gasket, float bowl gasket and bowl screw gaskets torque bowl screws to 35 inch pound
BlueOval Ralph is offline   Reply With Quote
Old 07-30-2012, 06:42 PM   #17
NORMAN BARNARD
Venturi's warped or metering block, quick check, move sec. Metering block(assumed it's not leaking) to the end having problem redo fill bowl and recheck for leak. If no leak it's the venturi.......mill flat, but recheck for clearance of p/v and stud boss in the area. I
ve had some come thru with "excessive" dichromate/bright zinc that would not let the plate gasket seal to the venturi and it dribbled out the off idle transfer slot in the base plate.
One more item to check, the cast in dowel pins in the metering block maybe bottoming out in their associated holes, place metering block minus gasket against venturi and check end-end and side-side for any "rocking". If there is, drill the holes or grind down the pins to fit the hole depth......
Old 07-30-2012, 08:09 PM   #18
Keith 944
Keith 944's Avatar
uggggh. i switched the metering blocks front to rear, rear to front. same leakdown. must be in main body, now what?
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 07-30-2012, 08:20 PM   #19
Steve Hayward
I have not read all the posts..... but if the front throttle blades are too far open, the carb will be sifoned through the transfer slot when the engine shuts off and cools down............
Steve Hayward is offline   Reply With Quote
Old 07-30-2012, 08:25 PM   #20
NORMAN BARNARD
Keith, find some one with a bridgeport milling machine that can true of the venturi gasket surfaces....any machine shop should be able to do it. When complete recheck metering block pin holes for correct depth.....good luck.
