#11 | |
The post concerning WAR cases is right on. If you aren't sure you have a nodular case I'd pass on it and get something aftermarket. |
#12 |
Liked 20 Times in 15 Posts
also note this. some cases use a 3.06 od side bearing and some use 2.89 od side bearings. i figure its a toss up. 289 have a thicker cap witha smaller bearing and vise versa.. either cap will use the 31 spline axle. with the correct side bearing. i recommend taping the main bolt holes as deep as you can and using either studs or as long a grade 8 bolt as you can [even to cutting an 8 to length. you should also have the bolt head seats spot milled to be square. the factory seats are not real good and the factory cap bolts are way short. tap the pinon support bolts as deep as you can and use longer grade 8 bolts with grade 8 washers there also. the cast iron Daytona support is the first best step. next is the bigger bearing supports. and there are several to go with choice wise. some use a big tapper roller some use a ball bearing, do some checking on your own as to what you want. but use something other than the factory, unless you are bucks down.
rod in AZ |
#13 |
Liked 204 Times in 93 Posts
thank you everyone for your help. what a wealth of knowledge on this site!
