Old 11-18-2011, 12:07 PM   #11
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: Tech West Racing Services MSD Upgrade
Tech West
I talked to a few guys about your upgrade this morning and they all seem to like it. I am going to try and get out one or two more times this year. As soon as I am done for the season my box will be on its way to you. Any info you could pass along about crossing over my plug numbers to fine wire would be appreciated.
Rob
Old 11-18-2011, 01:10 PM   #12
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
Tech West,
What if your using a 16volt system , I see all of your box checks are done with 12vdc can the box upgrade still be affective with a 16vdc system ?
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
Old 11-18-2011, 03:55 PM   #13
Jeff Lee
Jeff Lee's Avatar
Ever work with the ICE Ignition? PM me if you want too
Jeff Lee 7494 D/S '70 AMX
Old 11-18-2011, 07:39 PM   #14
68camaroSS
Tech West
What about the digital 7 boxes ? I have the 7530T. Last time I talked to you, you were not doing any upgrades to them. Is this because they are that good right out of the box and no improvements need to be made? thanks
68camaroSS is offline   Reply With Quote
Old 11-18-2011, 07:53 PM   #15
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Originally Posted by 68camaroSS View Post
Tech West
Yes, Pat....
Could you specify which (MSD) boxes benefit from your "upgrades"?
I am running the #7520 box with the #8261 coil.
Old 11-19-2011, 02:26 PM   #16
B Aceves
B Aceves's Avatar
Originally Posted by twrs2006 View Post
Upgrades are availible for the following, MSD 6a,6al,6aln,6t,7al2 and MSD 8 (7800,7802).
The following boxes already have faster switching transistors, MSD 7al3, 7al2 Plus,6632 HVC and all of the Digital 6's & 7's.
To step up the performance of the boxes we can't upgrade please take a look at the Maxpwr20 Voltage Regulator www.techwestracing.com/page21.html.
If you have any questions please feel free to contact me.
Pat,
I checked your web site on the max 20 Volt regulator and my question is on the B+ that goes between the power source and the unit if you are using a MSD #8830 noise capacitor that is in the same circuit does it matter which side the Max 20 is on of the capacitor or is it compatible with the Max 20? thx
Bob Aceves,
746 E/SA
A&M motorsports
Old 11-19-2011, 02:33 PM   #17
Chad Rhodes
Originally Posted by B Aceves View Post
Pat,
i would think it would have a filter in it
Chad Rhodes 2113 I/SA
Old 11-19-2011, 08:30 PM   #18
Barry Polley
Guest
Posts: n/a
Pat. I understand there is a new upgrade for the 7AL3. Can you tell me more?
Old 11-20-2011, 04:29 PM   #19
B Aceves
B Aceves's Avatar
B Aceves
Yes, part of the job Maxpwr20 does is provides clean DC voltage to the box. You can leave the line filter cap in place it won't hurt anything. In your application you would lift the Large Red wire & Large Black wire from their current connection points on the MSD box. Then the wires that provided + & - to the MSD box will instead provide the input power to Maxpwr20. Then you would take the output wires from Maxpwr20 and hook them to correct Large Red wire for + and Large Black wire for - . Look at it this way your just breaking the connections for main power and putting the Maxpwr20 in between the main power in & your MSD box. Also your Ignition switch wire will need to be removed from the small Red wire of the MSD box and connected to the white wire of Maxpwr20. Because Maxpwr20 will signal your MSD box when its time to play because you will hook up the ignition On ( small Red wire also to the output side of Maxpwr20.
If you have further questions please feel free to ask.
Thx for the info Pat !!
Bob Aceves,
746 E/SA
A&M motorsports
Old 11-20-2011, 10:34 PM   #20
428tom
can you do anything to Crane Hi-6 units?
428tom is offline   Reply With Quote
