#11 |
Banned
Liked 235 Times in 110 Posts
#12 |
Liked 2 Times in 2 Posts
HUH... I didn't know that.
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
#13 |
Liked 2,486 Times in 697 Posts
Thanks for all the input!!!!
The car I am Looking at is a "R" Code....... Should it be a "Q" for a Cobra Jet instead of a "R". Thanks, GTX JOHN |
#14 |
The only difference is the "R" code is a ram air car and the "Q" code in non ram air.
#15 |
Banned
#16 |
Liked 10 Times in 10 Posts
Hardtop Coupe versus Fastback 'SportsRoof',,,,,,,
For the dragstrip,,,,,and man-about-town,,,,,,,the Hardtop Coupe... Definitely a Northern USA car. For the roundy-round,,,,,long-haul parkway driving,,,,,the Fastback 'Sportsroof'. Definitely a Southern USA car. pc |
#17 |
1969 Ford Torino Cobra
In June 1969, Speed Age Magazine (formerly Drag Strip), got their hands on a 1 of 1, 1969 FordTorino Cobra. The Car; 69 Torino Cobra 'Hardtop Coupe; Color; Red Interior; Black Engine 428/335 HP 'Super Cobra-Jet' (non Ram-Air) 'Q' Code Factory Options; * Bucket Seats * GT Handling Package (Extra High-Rate Front & Rear Springs) (Extra Heavy-Duty Front & Rear Shocks) (Large-Diameter Front Sway-bar) * 6000 RPM Tachometer * Drag-Pak (Engine Oil-Cooler & 428 Super Cobra-Jet Engine) * 4.30 Gears w/Traction-Lock Differential * Heavy-Duty Battery (80-Amp) * Heavy-Duty Alternator (55-Amp) * Extra-Capacity Radiator * Close-Ratio 4-Speed Transmission (2.32 / 1.69 / 1.29 / 1.00) * Delete Options ( Radio, Heater, Body Sound Deadener) Dealer Installed; Factory Provided Components (Traction Drag-Pack II); * 15" x 7" Chrome Style Wheels, w/Chrome Trim Rings * F60 x 15" GoodYear R-W-L Tires (Front) * G60 x 15" GoodYear R-W-L Tires (Rear) * Traction-Master Traction-Bars * Extra-Thick Rear Shock Tower Plates Dealer Installed; Factory Provided Components (Drive-Train Drag-Pack III); * Hurst Competition/Plus Shifter * Schieffer Clutch Package (High-Rate Pressure-Plate and Heavy-Duty Clutch-Disc) Dealer Installed; Factory Provided Components (Free-Flow Exhaust Drag-Pack IV); * Special Low-Restriction Exhaust Pipes (2.75" diameter) * Special Un-Baffled Mufflers * Special Cast-iron Exhaust Manifolds (Exhaust port passages and header openings ground smooth) Dealer Installed; Factory Provided Components (Hi-Rev Engine Drag-Pack V); * Rev Limiter (5800 RPM) * High-Pressure Fuel Pump * Blueprinted Cylinder Heads (Lightweight Valves) (3-Angle Competition Valve Job) (Milled Surface and CC'd combustion chambers) (Intake and Exhaust Ports gasket-matched) (Performance Valve Springs) (Spring Height set) (Teflon Seals) * Adjustable Rocker-Arms * Edelbrock Aluminum Dual-Plane Off-Set Intake Manifold (#FE-427) * Intake Heat-Crossover Passage Block-Plate * Holley 780 CFM Carburetor (Vacuum Secondaries) * Dual-Point Distributor (427) * Solid-Core Ignition Wires Performance Results; (Post your guess) Note: A 'factory showroom' 69' Torino Cobra, with a 428 Super Cobra-Jet (Q-Code), 4-Speed close-ratio transmission, and Drag-Pak (4.30 gears), with stock F70 x 14 tires, could run; 13.85's @ 102 MPH. Last edited by Paul Ceasrine; 11-08-2011 at 05:51 PM. |
#18 |
Liked 4 Times in 3 Posts
With that rev limited set at 5800 I can't see it even making it through the traps with 4.30 gears G60 tires.
But I'll guess 13.30 hitting the limited from 1100 foot on. ![]() I had one for many years. Black "R" code SCJ coupe with every option imaginable. 1969 FoMoCo Chicago Auto Show special build. I bought it from the original owner who lost his licsence. Very fast street racer that made me a lot of money. Sold it to Tony's Godfather during my divorce and he still has it as far as I know. I'll post some pics.
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK Moneymaker Racing LaPorte Indiana 219-861-1214 www.moneymakerracing.net |
#19 |
I would also agree that it would be on the chip and low 13's. If they didn't have the rev limiter set so low I would say it should be in the high 12's.
#20 |
Alex and 69 Cobra,,,,
Excellent analysis,,,,,,,,,,,,, Speed Age got the car to run a best of 13.18 @ 109.5 MPH Average times were in the 13.20's @ 108 MPH. The Rev-Limiter was put in for a 'reason', obviously...as the test was controlled and observed by a 'neurotic and extremely nervous' Ford Dealer representative. The Speed Age Magazine car-testers came to the conclussion; * removal of the Rev-Limiter, * install 7" 'M & H' slicks on 15" x 6" rims * thinner front tires 7.35 x 15" * tweak the Holley 780 CFM carburetor Estimated Performance; 12.80's @ 112 MPH. |
