Old 11-11-2011, 07:49 AM   #11
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default Re: engine misfire on 350 vortec
Originally Posted by JWhalen58 View Post
There is a you tube video on this.
Link?
Old 11-11-2011, 10:06 AM   #12
JWhalen58
Liked 117 Times in 21 Posts
Hey I just learned how to send a text message last summer. It is titled trick to fix fuel injector on buick 3.1 engine.
JWhalen58 is offline   Reply With Quote
Old 11-11-2011, 10:55 AM   #13
buzzinhalfdozen
Liked 11 Times in 8 Posts
2 different types of fuel injection. the 3.1 uses a simple pintle type injector, the engine he's working with uses an injector plus a poppet nozzle in the end of the feed hose. Though it is possible for either of these to malfunction. The poppet type injector is a bit harder to diag. since you're dealing with 2 possible issues, a pressure drop test is typically used by comparing the amount of drop you can identify a "problem" injector be it the injector or the poppet unless cleaning fixes the issue replacement of the injector, poppet included is required. Joe
Joe Buchanan SS/BX 3117
Old 11-12-2011, 09:41 PM   #14
Doug Domm
Liked 84 Times in 21 Posts
We are now in full on winter and it hasn't skipped a beat since it turned cold even at operating temp. I am thinking that with the cold ambient temp (winter) it is calling for more fuel and delivers the higher rate just fine. It always seemed to show up when fully warmed up and at dead idle with very small fuel requirement. If you turned on the air it would smooth out because of the higher fuel demand to run the air or if you would break the throttle just off idle it would run fine. Frustrating!!
Doug Domm is offline   Reply With Quote
