Old 05-04-2010, 11:52 AM   #11
Everett Vassar
Liked 2 Times in 2 Posts
Default Re: miss. in eng
Man it sure sounds like plugs.I know you changed them.Might try another set different brand. Also check for moisture/condensation inside the dist cap and the plug wire sockets.Do you keep the car outside?
Everett Vassar is offline   Reply With Quote
Old 05-04-2010, 09:16 PM   #12
1299
Liked 54 Times in 12 Posts
stay in enclosed trailer same as it did last year
1299 is offline   Reply With Quote
Old 05-10-2010, 04:19 PM   #13
1299
will i can say that it is not fuel problem.will try new coil and plug next weekend
Old 05-10-2010, 05:25 PM   #14
Brian Fink
Liked 28 Times in 9 Posts
Pat Collins ( TechWest Racing Services ) is right on regarding loose or oxidized connections to the coil / MSD ; been there done that . It may not be the problem in this case , but is good advice for any racer.
Brian Fink is offline   Reply With Quote
