Old 11-09-2008, 09:39 AM   #11
John Dinkel
Liked 263 Times in 68 Posts
Default Re: Attn. Mopar Stocker racers?????
I broke a bearing cap on my 489 case. Destroyed the ring and pinion. Had to take the trans out to check the over running clutch.
It has not happend on the 742.
John Dinkel
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 11-12-2008, 11:43 AM   #12
mike natoli
mike natoli's Avatar
Liked 51 Times in 16 Posts
Question Re: Attn. Mopar Stocker racers?????
I'm interested getting ready freshen and order replacement set of 5.13 gears 5.0 would be just right. What is the ETA and who are we ordering them from.
Best Regards,
Mike
mike natoli is offline   Reply With Quote
Old 11-12-2008, 12:24 PM   #13
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
I would definitely be interested in a couple sets of 5.00 pro gears but for a 742 case only. I have run the 742 case for over 35 years ... I think the straight pinion is much stronger than the tapered ... Jim Nichols did the same thing John Dinkle did to his 489 case, busted the bearing caps off both sides. I have broken at least 4 ring and pinion sets in a 742 case and I am still using the same case ...
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
Old 11-12-2008, 01:42 PM   #14
Jeremy
I also broke a 489 cap which took out the ring ,pinion and transmission on the class final at Indy. I have seen the new 489 case's and they apear to be much stronger than the older ones.
Thanks
Jeremy is offline   Reply With Quote
Old 11-12-2008, 01:58 PM   #15
chlngr73
I would be interested in two sets pro gear and 489 case only. The new 489 cases comes ready out-of-the-box, no need for billet caps, and easier to assemble.
Thanks
David Buckner STK 4772
chlngr73 is offline   Reply With Quote
Old 11-13-2008, 12:34 PM   #16
Chuck Beach
Jim,
What is the status of these gear sets being made? thanks
Chuck Beach
3340 STK
Old 11-14-2008, 09:31 PM   #17
Jeff Teuton
Liked 325 Times in 50 Posts
I will take one set, but would prefer the 742 case. I have knocked the caps off too many 489 housings. But I will take the 489 if that is what it takes to get it done.
Jeff Teuton 4022 STK
Old 11-16-2008, 11:05 AM   #18
Jim Storms
Liked 4 Times in 2 Posts
Thumbs up Re: Attn. Mopar Stocker racers?????
Thanks everyone for all the input and replies, not to dicourage any of you but they will not be making any of the Pro gear sets, at the current time we are working on getting sets built for the 742 case only at this time. i was told there will be about a 4-5 month duration to get these built! i was told it's a tooling thing. we hope to have the first 50 sets availible about April. thanks again,
Jim Storms is offline   Reply With Quote
Old 11-20-2008, 06:26 PM   #19
Jim Bailey
Liked 547 Times in 93 Posts
Hey Jim ( and other Racers ), We can Cryogenic Process and/or Rem Finish your gear sets. I wouldn't even worry if they weren't Pro Gears. I can't get Pro Gears for my car. ( 742 case 4.56 ). Ask # 1 qualifier at most Div.3 races - Chuck Beach - if he's broken any gears lately! Or better yet, what changes he made to his car that increased his performance this past year. Or ask, Michael Beard, Jeff Day, Scott Macy, John Dinkle, Phil Baldichino, Cheatin' Charlie Downing, to name a few, what they think. You can expect 2 to 3 times the gear life with quieter, better performance. It's cheap insurance.Thanks, Jim Bailey
Jim Bailey is offline   Reply With Quote
Old 11-21-2008, 05:42 PM   #20
NovaMan
NovaMan's Avatar
How much of that is from the cryo treatment, and how much is from the rem finishing?
~Pete
1970 Nova
NovaMan is offline   Reply With Quote
