Old 01-12-2009, 08:05 AM   #171
bsa633
Banned
Smile Re: Crate Motor Class
Crate MoPar's in NHRA. The Nascar Hemi with the short or long track intake, any carb that will fit under the hood and aluminum heads.
See there is a place for Crate Motor "Bracket Cars" in NHRA Stock Class!
And i thougth you would name a couple of FoMoCo products,,
bsa633 is offline   Reply With Quote
Old 01-12-2009, 05:11 PM   #172
Fred Holdorf
Default Re: Crate Motor Class
This thread got me to thinking. Why is the only small block Ford Crate motor with specs, not on the list of accepted motors? Why are the specs on the 4 that are listed not published for someone to see? I'm not an IHRA member, due to living on the left coast so this is just a question at this time. I don't believe the 4 listed engines have been available, as assembled motors, for quite some time.
Fred
P.S. If IHRA came west I would be intrested in racing in their program.
Fred Holdorf is offline   Reply With Quote
Old 01-12-2009, 09:59 PM   #173
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Fred
I hope somebody can answer your question,but sorry I can't help you.One question that I do have about crate motors is that it has been brought up earlier in this thread that the H/CM class is a 9.5 horsepower to weight class.D/SA is also a 9.5 horsepower to weight class.I was just wondering why the index is 12.00 in H/CM and 11.85 in D/SA?How are the factors of these crate motor engines determined and why the difference in the index?
Old 01-12-2009, 10:00 PM   #174
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
The difference in index was to allow for racers to build a crate combo on a budget and be able to run the index.
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 01-12-2009, 11:02 PM   #175
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Drag racing affirmative action.
Ed F.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 01-13-2009, 12:12 AM   #176
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Do you think that a 350/340HP crate motor would run with a 396/325HP? I don't think so.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 01-13-2009, 11:28 AM   #177
Bobby Zlatkin
Bobby Zlatkin's Avatar
What I have been thinking about this situation (index differences) all along:
When nine or ten of the top 10 qualifiers are crate motor cars and they're accross the board; it's not the HP factors being soft as much as it's the indexes being soft..
Why should the 9.5 lb. stock index and the 9.5 lb. crate motor index not be the same?
And LNorton, your explanation of why they are different is totally out in left field.
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 01-13-2009, 11:36 AM   #178
LNorton
LNorton's Avatar
Crate motor classes were started as an outlet for racers to be able to build a car and compete in stock on a low budget. So in order to make it easier for newcomers to get under the index and race on Sunday the indexes started off soft. You may think I am out in left field on this one...
When I was running pure stock I was told those indexes were soft and were gonna get hit 2 tenths.
RacerTees.com
Old 01-13-2009, 11:53 AM   #179
Bobby Zlatkin
Lee,
Any thought of a crate motor class being a budget class is a misconception. How can it cost any less to build a first class crate motor car than a first class regular stocker?
That may have been the original thought but it has progressed far beyond that now.
Old 01-13-2009, 11:56 AM   #180
LNorton
LNorton's Avatar
Well, I will tell you all this. Whining about it on a message board really doesn't do anything. If you want changes, you need to be writing letters.
RacerTees.com
