Old 03-04-2017, 09:10 AM   #161
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
Default Re: Boss Mustang stocker
The approved aftermarket block program is moving along (this is an aluminum version to sort out the machining operations prior to mass market) Iron versions will be cast soon. Both aluminum and cast iron will be the strongest cast blocks on the market from any manufacturer, because of material, casting process and other advancements in design, in the pics material will be added to achieve the proper lifter phasing with the canted heads.
The Iron block is approved for NHRA, the aluminum and iron is approved for NMCA prostock
Bill Diehl B200 C/D STK
Bill Diehl is offline   Reply With Quote
Old 03-08-2017, 08:50 PM   #162
Dave Noll
Dave Noll's Avatar
Liked 238 Times in 111 Posts
Will the Stock legal iron block have those lifter bore angles ?
Dave Noll, EF/S ,?/SA 6526
Old 03-09-2017, 08:28 AM   #163
Bill Diehl
Bill Diehl's Avatar
The blocks will be machined at 45 degree standard Cleveland lifter phasing angle, but those in the pics I posted will be available as an option
Old 03-09-2017, 12:38 PM   #164
cicero819
cicero819's Avatar
Liked 69 Times in 30 Posts
Bill great Job building your Mustang. How is the bodywork coming along? You've got a great post going. CR
Old 03-09-2017, 12:55 PM   #165
Bill Diehl
Bill Diehl's Avatar
slow...I have 2 new doors and 2 new front fenders so not much bodywork to do...making it all fit is the hassle, actually its not to hard. I have the whole car clecoed together for fit and finish then take it all apart, make adjustments and weld. putting a skin on a tube car is a thousand times faster and easier than this is
Old 03-09-2017, 12:58 PM   #166
Bill Diehl
Bill Diehl's Avatar
also I see today that Mark McKeown has got his Titus block program approved for 351c racers..Congrats and thank you Mark!
does that mean there will be an overflow of fords out there now?
Old 03-18-2017, 08:00 AM   #167
Bill Diehl
Bill Diehl's Avatar
The ford aftermarket is stepping up its game...the strongest blocks on the market 351C CGI (compacted graphite iron)
available from Tim Meyer Inc
Old 03-18-2017, 08:22 AM   #168
dusterfinland
Liked 4 Times in 3 Posts
Nice Job,.good pictures.
dusterfinland is offline   Reply With Quote
Old 03-26-2017, 12:10 PM   #169
StickBBF
Say Bill,
A couple of questions:
Back on post #91 you provided some block casting prices,,,, Can I assume those prices would include the 'basic machining' required - or if not, what does that usually add to the cost?
Do aftermarket blocks typically come with main caps - if not, what do most builders typically go with / recommend?
Thanks for sharing your build and knowledge.... it's been very educational...
StickBBF
StickBBF is offline   Reply With Quote
Old 03-26-2017, 03:52 PM   #170
SSDiv6
Liked 1,580 Times in 582 Posts
Originally Posted by StickBBF View Post
Say Bill,
StickBBF
Go to Tim Meyer's website:
https://www.tmeyerinc.com/category-s/1970.htm
Tim has a lot of options on the block and also special pricing on the first batch of CGI blocks.
When compared to a Dart block, Tim's block is a bargain. Normally Dart will charge and additional $2500.00 ~ $3500.00 for a CGI material block and a long wait.
