Old 05-25-2015, 03:39 PM   #121
Alan Nyhus
Liked 770 Times in 230 Posts
Default Re: Nova stocker project.
Took care of my hood louver 'problem' by having these decals made at local place that does vinyl wraps:
"That'll never work....."
Old 05-25-2015, 04:46 PM   #122
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
How about a wrapped hood minus the hood underneath Alan?
Rich Taylor
I/SA - 321
Old 10-10-2015, 10:08 AM   #123
Alan Nyhus
I thought this might be a good time for an end of season update.
Midway through the season, I made the decision to change from the Powerglide to a Metric 200. Thanks to Jim Marshall and Billy Lynn for all their help and assistance with this.
There were a couple of glitches, one of which was a nasty leak out of the tail shaft seal. As it turns out, the drive shaft yoke had been machined to work with a different tail shaft bushing, thus the leak. A new yoke and a drive shaft rebalance and we were good to go.
The car ended up going a best of .71 under the NHRA index in G/SA at the test and tune session at the Oahe National Open in Pierre, S.D. We had some mechanical gremlins to deal with through the season...a broken starter at Oahe ended up thrashing the flexplate as well. Thanks to Steve Koppien's spare parts stash and my brother Kevin's assistance, we were able to fix it Saturday afternoon. At Kearney's National Open, I went to start the car in the staging lanes for the third round of the Stock/Super Stock combo and a broken cable strap let the battery cable short out against the header tube......arrrrggghhh.
But all in all, not a bad season.
Tim McVay photo.
Old 10-10-2015, 11:14 AM   #124
HandOverFist
At .71 under you have that Nova working pretty good Alan...great work! That's a massive brace on that metric.
Rich
Rich Taylor
I/SA - 321
Old 10-12-2015, 09:47 PM   #125
OLD INJUN
Originally Posted by alan nyhus View Post
i thought this might be a good time for an end of season update.
Midway through the season, i made the decision to change from the powerglide to a metric 200. Thanks to jim marshall and billy lynn for all their help and assistance with this.
there were a couple of glitches, one of which was a nasty leak out of the tail shaft seal. As it turns out, the drive shaft yoke had been machined to work with a different tail shaft bushing, thus the leak. A new yoke and a drive shaft rebalance and we were good to go.
the car ended up going a best of .71 under the nhra index in g/sa at the test and tune session at the oahe national open in pierre, s.d. We had some mechanical gremlins to deal with through the season...a broken starter at oahe ended up thrashing the flexplate as well. Thanks to steve koppien's spare parts stash and my brother kevin's assistance, we were able to fix it saturday afternoon. At kearney's national open, i went to start the car in the staging lanes for the third round of the stock/super stock combo and a broken cable strap let the battery cable short out against the header tube......arrrrggghhh.
but all in all, not a bad season.
tim mcvay photo.
it sounds like b - - s - - - - - - - has been working on the car !
OLD INJUN is offline   Reply With Quote
Old 01-18-2016, 09:38 PM   #126
Alan Nyhus
Should be going back together in a week or two.
Old 01-19-2016, 09:17 PM   #127
Charlie Berner
Charlie Berner's Avatar
Liked 8 Times in 2 Posts
Maybe we should go south?
Charlie Berner is offline   Reply With Quote
Old 01-23-2016, 07:54 AM   #128
Alan Nyhus
Won't work for me this season, Charlie. Several of our locals are headed to Phoenix and Pomona, though.
Old 01-26-2016, 12:45 AM   #129
corky
corky's Avatar
Al If I can get my stuff together to go so can you . And drag Charlie and Dave with you. Corky
corky is offline   Reply With Quote
Old 03-18-2016, 07:51 AM   #130
Alan Nyhus
An simple rear shock change turned into a three week project. I wanted to change one thing a little so that meant another thing needed to be redone. This led to that...blah, blah, blah. You guys know the drill, right? Anyway, the rear is back together with new spring bushings, shackles, hard brake line from the master cylinder on back, stainless lines to the wheel cylinders, stainless rear flex line, wheel studs, rear bearing seals and rear brake shoes.
And the new rear shocks that started all this!
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
