Old 06-06-2019, 11:54 AM   #1251
1matcoman
1matcoman's Avatar
Liked 372 Times in 142 Posts
Thumbs up Re: H-I-J '76 Nova re-fit.
Wow! Todd, if there ever was a mulligan for letting a car like that get way, that would be it.
Old 06-06-2019, 09:40 PM   #1252
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
Ordered some parts this week, Hardblok, Racepak stuff, head gaskets, main studs, head bolts and a crankshaft. Pretty sure I wont get the block tomorrow but I'll call to check just in case.
Todd Greene
Old 06-06-2019, 11:35 PM   #1253
HP HUNTER
Liked 373 Times in 129 Posts
Originally Posted by Nmbr1GMfan View Post
I honestly don't see this as being questionable. How is a 400hp stock block an issue?
Its not, if you start with the right core and know what to do with it. And you should have more than 400 HP if you get it right.
I know of at least one S/S that runs extremely well with a production block, its all about the core and the prep.
Old 06-08-2019, 02:23 PM   #1254
Nmbr1GMfan
Not sure if I have the right one and not sure if I'm doing it right but I'm doing it. The learning curve... it is steep.
Todd Greene
Old 06-08-2019, 03:35 PM   #1255
james schaechter
Liked 1,443 Times in 302 Posts
I don't really have any money in it, maybe a few hundred dollars. There's no way I'm the only guy that's running a stock block. Especially since I had a two bolt with stock main cap bolts to begin with.
One of our 275 327 E stick engines is a .040 over stock block. Probably well north of 500 runs on it. ( been freshened several times) it has been 10.70’s in decent air. We call it super street because it will run at least 10.90 in any conditions.
I think the key is that it hasn’t been bored bigger. We even coated the Pistons to help the sizing over time.
We had a 327 once that we filled and ran .060 over. My preference to to not run a filled block if I can avoid it. Either a thick enough stocker or an aftermarket
James Schaechter 3163 STK
Old 06-08-2019, 07:08 PM   #1256
Nmbr1GMfan
Made a new "wavy washer" today and got the Racepak bulkhead in, made some templates for brackets, moved some carpet for cables and made a new hole for the switch panel ribbon cable, looked like crap running across the firewall.
Todd Greene
Old 06-09-2019, 02:42 PM   #1257
Nmbr1GMfan
I didn't get much accomplished this weekend, dragging my rear. Sunday I worked on the trans. getting the Racepak stuff started.
Todd Greene
Old 06-10-2019, 08:23 AM   #1258
Liked 11,028 Times in 2,266 Posts
Will the Race Pac be affected being that close to the coil? Car is looking good!
Old 06-10-2019, 09:25 AM   #1259
Nmbr1GMfan
Racepak said as long as the box isn't near it should be good so I hope not.
Todd Greene
Old 06-10-2019, 09:47 PM   #1260
Nmbr1GMfan
Parts. And these bearings didn't come loose in a carboard box.
Todd Greene
