06-03-2019, 08:34 PM | #1231 |
Liked 1,958 Times in 493 Posts
Re: H-I-J '76 Nova re-fit.
Those are the standard "grey iron" cap.
Todd Greene |
06-03-2019, 09:34 PM | #1232 |
Liked 281 Times in 151 Posts
Todd check yet PM Dick
06-04-2019, 07:41 AM | #1233 |
I saw that about the desiccant plugs? My PMs are wacky sometimes and I cannot respond but I did see this Thanks.
Todd Greene |
06-04-2019, 03:51 PM | #1234 |
Dropped the block off today, it'll most likely be a week before I get it back to start machine work.
Todd Greene |
06-04-2019, 11:46 PM | #1235 |
Liked 654 Times in 209 Posts
Seems to me that aftermarket steel main caps are available someplace for 4 bolt main 350's,must be better than the originals.Just trying to remember where I saw them.
06-05-2019, 08:38 AM | #1236 |
They're everywhere, lots of aftermarket ones for sale.
Todd Greene |
06-05-2019, 12:13 PM | #1237 |
Liked 822 Times in 264 Posts
Why put money into a questionable foundation.Cleaning block, Filling block, installing main caps etc.
06-05-2019, 02:51 PM | #1238 |
Liked 510 Times in 200 Posts
30 years ago we sonic tested and Brinell hardness tested all small blocks.
The range from soft to hard was pretty significant.....and a hard block would easily make more power. Ideal was hard and decently thick cylinder walls..... .060 over was a lot..... Cylinder walls were just about always not consistant Core shift could be ridiculous You can usually see the cam being off center by the flat machined surface at the face of the cam hole...not concentric I had one engine I built at home that was so far off center it was silly The crank and cam centerline were way off center. So bad I had to get different rods. It was a 383 and I could not get clearance on one side for the rods to block even after grinding and the other side went right by with plenty of clearance..... Aftermarket and even Bowtie blocks are far better.... Just sayin!!!
Rich Biebel S/C 1479 |
06-05-2019, 05:51 PM | #1240 |
I honestly don't see this as being questionable. How is a 400hp stock block an issue?
Todd Greene |
