#111 |
#112 |
Liked 54 Times in 33 Posts
C'mon....guys. Man, it's pretty damn simple to me. These Lane guys are smart. And they knew if they waited long enough the heat in all of the engine and surrounding metals would cool, adding lots of oxygen molecules to it thus making the car heavier and la-la, make weight.
Really. |
#113 |
Liked 129 Times in 53 Posts
You can't help to think how this whole deal would turned out if it was a 396 Camaro that was involved, it would probably have been a 50/50 situation on here
![]() Last edited by Race Clean; 07-18-2019 at 04:46 AM. |
#114 |
Liked 10,921 Times in 2,257 Posts
I thought it was a 427 Camaro
#115 |
Does this have anything to do with what's going on here?
http://www.nhraracer.com/content/gen...579&zoneid=132
#116 |
Liked 425 Times in 56 Posts
That is because last year I let them know that the 1973 has a different body and , intake manifold .I asked them to separate the 1974 and 1973 corvettes.. They answered me saying not only are the body and intake different but the 73 has different head. Now after getting the horsepower increase I wrote and reminded them that last year they separated us in the year end stats. This was there answer. With the stroke of a pen they made the parts legal on the 1974.
Gary Parker 1617 STK Last edited by Gary Parker; 07-18-2019 at 09:54 AM. |
#117 |
Liked 653 Times in 89 Posts
Once again a -1.20 run with no tear down (Thanks Div 6 for confirming you are the weakest div of the 7). Why is it so hard to check spec's and make sure the combo is 100% right after some earns hp for a combo NHRA? If I had that combo I would protest Lane the next race just on principal and the works rod piston,everything.
NHRA Runs of -1.20 or faster should be automatic tear down NO MATTER WHAT LBS THE CAR CROSSED THE SCALES AT. NHRA Runs of -1.00 should be a mandatory carb/throttle body check and casting numbers. This will stop a lot of the BS problems we have now in SS and STK on heads up runs I guess if NHRA is not going to do this the group of racers in D3 will try and keep our div some what on the up and up(More protest to come).
Charley Downing 3548 STK |
#118 | |
Liked 250 Times in 49 Posts
#119 |
Liked 451 Times in 134 Posts
I thought that was the norm if you didn't tear down you were out for a year and when you came back you had to tear down then,I didn't know they ever changed that ?
Jerry Retired 3490 3492 Stk SS SST Last edited by Jerry Terry; 07-18-2019 at 10:23 AM. Reason: add |
#120 |
Liked 208 Times in 35 Posts
Gary, check your pm. Rick
Rick Winchester Stk 3277 |
