Old 11-06-2011, 03:37 PM   #111
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Default Re: Roller Rockers in Stock
Originally Posted by Greg Hill View Post
Stud mounted rockers are what I was told and that jessel or t&d rockers are not legal. I think you all know what i meant.
The IHRA rule is no T&D or Jessel type system at all. If its a stud type OEM mounted rocker system then it has to stay that way. No conversions!!! If is an OEM shaft rocker system then shaft rockers are OK on combos that use them from the OEM such as the FE Ford, 273-360 Mopars, 361-440 Mopars and Hemis and others.
No trick set ups and must maintain OEM rocker ratios only. No under cut cam lobes with non OEM rocker ratios. No Jomar type girdles at all.
Old 11-06-2011, 03:56 PM   #112
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Roller Rockers in Stock
Originally Posted by Aubrey N Bruneau View Post
I was wondering when someone would finally point that out !
I'm a Chevy guy... pre 73 that is. No shafts there. However, to my knowledge, don't most Mopars of that earlier era, have shaft rockers ?
I'm sure it's safe to assume that the new rule will at least madate that the engine has to possess the original rocker configuration.
Does that mean that the shaft-rocker engines will have an advantage ?
perhaps a little
That's the way it is.
What in the world do you use for a roller rocker on a 409? When I played with those things, the Ford 351 Cleveland rocker arm was pretty close, so was the Chevy 6-250-292 etc. type of rocker arm.Just curious what you do for those.
Old 11-06-2011, 05:10 PM   #113
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Greg... BBC standard BBC 1.7 ratio ( factory W block is 1.75... but there's nothing in that ratio that handles this abuse ! ). Let's me use the BBC 7/16" stud. Cam has net lift at the valve, of .496" -.500". It all works.
Also, Crane has always had their P/N 15750 gold aluminum rocker for the W engine ( 3/8" stud )... it too, is 1.7 ratio.
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 11-06-2011, 05:55 PM   #114
Woodro Josey
Liked 3 Times in 1 Post
So, has anyone seen this in writing, i know Greg says Chris at Comp Cams has, but has anyone seen the rule laid out?
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 11-06-2011, 05:58 PM   #115
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Right now,I would be more concerned about what Charley Downing posted:
Now all the news from SEMA. New carmaro looks great MPR did a great job like always.
New Stk rule changes on the table for 2012
64 car fields for ss and stk at all nationals but Indy.
For stock only 1980 and newer cars only.
Old 11-06-2011, 06:55 PM   #116
Greg Hill
Liked 279 Times in 68 Posts
Surely you don't believe Charlie's BS.
Greg Hill 4171 STK
Old 11-06-2011, 07:00 PM   #117
442OLDS
442OLDS's Avatar
No,but it is entertaining.
And I suppose the manufacturers would want to get rid of the older cars,since most of them win the National events.
Old 11-06-2011, 07:10 PM   #118
X-TECH MAN
Banned
The manufacturers want to see their NEW cars win National events. They dont give a "Flying you know what" about the old cars. I hope Charlie is wrong or pulling everyones leg but NHRA has pulled this stunt before in 1972 and got away with it.
Old 11-06-2011, 08:02 PM   #119
Peter Ash
Peter Ash's Avatar
Kind of makes you wonder, if the new COPO comes with roller rockers already? This possibly being the reason for the suggested rule change? Wouldn't that be a nit in the soup for the CJ and DP bashers, lol.
Peter Ash is offline   Reply With Quote
Old 11-06-2011, 08:03 PM   #120
james schaechter
Interesting letter to the Editor that was in a 1970 Dragster that I bought at a swap meet today.
James Schaechter 3163 STK
