Old 12-08-2020, 10:33 AM   #101
Billy Nees
Liked 7,789 Times in 1,744 Posts
Default Re: Not for Nuthin' But Close!
Originally Posted by Tom Meyer View Post
More stuff. Did you know that cavilers had three different spring packages for ride and handling. I think you could keep your weak springs in the front but go with heavier in the rear or stack 1/2 washers under the rear rear strut mounts and adding spring rubbers too, keeping more to the front and giving the car some front rake. Also make sure your rear struts are not leaking and are hard to compress. If you are doing stuff too the trans, welding the spiders may be a option, but you will have to get the front alignment right so it rolls easy. More to come. Tom
With the wheel/tire combo that's on the car it definitely has a forward rake. I've had to raise the front slightly to get to the 3" minimum ground clearance.
A million years ago, I played with "welding spiders" in a FWD car. That won't happen again.
Billy Nees 1188 STK, SS
Old 12-08-2020, 12:23 PM   #102
Times 2 !
Old 12-08-2020, 08:49 PM   #103
Tom Meyer
Liked 354 Times in 120 Posts
They do make LSD for these to. That would ruin the nickel part. We use spring rubbers on the dirt to make the car turn. Tom
Tom Meyer 5240 SS Stock ???
Old 12-09-2020, 11:38 AM   #104
vic guilmino
Liked 56 Times in 21 Posts
anybody like to help me tune my 2005 GTP cone air filter and high flow cat. i have a hp tuner with O2 hook up.
Vic Guilmino 1129 STK
Old 12-10-2020, 03:41 AM   #105
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Times 2 !
Would be interested to hear about these as I was toying with doing this on the Escort. Is it the torque steer or something else. I did find an lsd for it though.
Dave Noll, EF/S ,?/SA 6526
Old 12-10-2020, 10:31 AM   #106
Dave Gantz
Liked 251 Times in 125 Posts
Aren't welded spider gears illegal? I wouldn't want to be on either end of that law suit. (The one that could ensue when an accident occurs because a weld or gear broke.)
Old 12-10-2020, 10:42 AM   #107
Billy Nees
First of all and probably the most important, it will be VERY difficult to steer the car and I mean just driving it around the pits. It will slow you down and not just a little bit. If you break your welded spiders, you had better hope that you do it on the line otherwise you WILL be going for a "ride".
Old 12-10-2020, 10:48 AM   #108
Billy Nees
Yup. Under General Regulations 2:11 Rear End,Welded spider gear rear ends prohibited in all classes.
Old 12-10-2020, 07:43 PM   #109
Tom Meyer
They do it a lot in the fwd Dirt cars, never ever hear of anybody breaking one. Seen a bunch blow the the trans apart from the spiders spinning and cutting the pin in half. For setup you run less air from left to right for stager to go around corners and with the gears harder than the shaft it eats it up. For some of the rwd classes they have to run a mini spool with just the pin making it solid. If you work on the PS a little it does not take away any hp. 99 % of the all the dirt cars and nascar run PS. Its a old wise tail now days. How many time do you hear that somebody lost there PS and fell back out of contention, back in the day when nobody had it took a man to drive 500 miles. Tom
Old 12-11-2020, 09:35 AM   #110
Billy Nees
Tom, I know that dirt tracks can get really "sticky" but, as I'm sure that you know, it's nothing like a "glued concrete" starting line. And there's not much need for P/S on a drag strip. Taking off the P/S pump and laying it aside was worth .08.
