Old 06-06-2012, 09:54 AM   #101
KRatcliff
Liked 534 Times in 143 Posts
Default Re: Help!! Engine Miss
Originally Posted by Tim Lisson View Post
You mentioned in one of the posts recently it does rev up freely without load? You need to take this to a drag strip and get after it.
Also, i would verify your alternator is working properly along with a seperate ground wire from the alternator to the head. I know what your thinking, it's bolted to the block...
It is funny you mention that. I bought 100' of the braided ground strap material from Ebay. Do you know how far 100' will go?
Lets just say that if I ever crash my car, I won't die from the impact. It will be from strangulation.
KRatcliff is offline   Reply With Quote
Old 06-06-2012, 01:11 PM   #102
Ben Kallies
Tim,
Leakdown test was performed cold. Engine hasn't been run in 2 weeks.
-Ben
Ben Kallies is offline   Reply With Quote
Old 06-06-2012, 01:40 PM   #103
Tim Lisson
Ben,
First of all, I'm no expert so take this for what it's worth....
1) After dyno session, did you back the rockers off when it sat until you got it in the car?
2) When I do a leak down, I typically run the car up to 140-150 then attempt to zip through the test with warm cylinders. The cylinders that are over 5% I would smoke test, go by a cheap cigar and have it over the carb/intake opening and exhaust port/ header tube when performing this scientific test... don't laugh, it works.
Other than everything else mentioned, get it to a track or bring it up north. My trans builder has a chassis dyno and has had many BBC on it. Sounds like a fun mystery!
Tim
Tim Lisson is offline   Reply With Quote
Old 06-06-2012, 01:42 PM   #104
Liked 1,923 Times in 432 Posts
Now the chassis dyno sounds like an excellent idea, that's even better than track time. you test the whole car, and you can hook diagnostic equipment to it and then duplicate the problem.
Old 06-06-2012, 05:11 PM   #105
Ben Kallies
I've actually been thinking about the chassis dyno idea for a couple of weeks now. There's a speed shop with an in-ground dyno about 10 miles from my house. I'm not certain how experienced the operators are in terms of diagnostic abilities, but at the very least, I'd be able to see how it responds at full throttle under load.
-Ben
Old 06-06-2012, 11:52 PM   #106
Arnold Greene
Liked 3 Times in 2 Posts
Ben, make sure you have plenty of clutch pressure before you put it on the chassis dyno. Good luck.
Arnold Greene
IHRA/NHRA 2420 A/S, B/S
Arnold Greene is offline   Reply With Quote
Old 06-07-2012, 04:35 AM   #107
Ben Kallies
Arnold,
Thank you. I wouldn't have thought of that.
Old 06-07-2012, 01:13 PM   #108
SC321X
Smile Re: Help!! Engine Miss
Have you looked at the valves to make sure they all open the same as you bump over the motor(no mess that way) If they all seem to open all the way chances the cam is ok. If this car is an automatic I would unbolt the torqconverter and see what difference that makes. make sure you push it back out of he flywheel.
SC321X is offline   Reply With Quote
Old 06-07-2012, 11:13 PM   #109
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Originally Posted by Ben Kallies View Post
OK, so the leakdown test is done. I checked each cylinder twice with the same results each time. Results are as follows:
cyl 1 12%
cyl 8 10%
cyl 7 11%
cyl 3 7%
cyl 6 5%
cyl 5 12%
cyl 4 11%
cyl 2 8%
It's my impression that these results are good. Thoughts, comments? Is a compression test still necessary, or do these results verify the health of the engine?
Thanks,
-Ben
Run a compression test anyway. If you have a flatttened cam lobe-particularly intake- the compression may show low on that/those cylinders. Happened to me on a brand new motor.
Mike Moller
Old 06-11-2012, 10:33 AM   #110
Gary Wiegand
Hi Ben,
This is my first reply on this site, so hopefully I get it done correctly.
Before I describe a similar situation which I had, trying to chase down a "miss" in the engine, and what was causing it, I have one question; do you have a spacer plate below your carburetor?
Gary Wiegand is offline   Reply With Quote
