#91 |
All the new NHRA phony baloney valve job all done, already?
#92 | |
![]() ![]() Quote:
![]() Last edited by SSDiv6; 05-02-2017 at 10:32 PM. |
#93 |
Liked 704 Times in 281 Posts
I went with the .005 per 1 CC and what I ended up with after being to small was .003 per 1 CC. I mistakenly just went for it and didn't check between cuts and ended up 6 cc's to small. So instead of cutting valves seats deeper and try and get back the 6 cc's ( which I doubt I could)I just bought a head. The second head was brought down the right amount and checked during cutting and the .003 per 1 cc worked on this head. Tomorrow the third head will be checked and should be ok. With this being my first time building instead of paying I learned a great lesson.
#94 |
After sitting home tonight thinking about it I'm guessing if I had 2 different thickness head gaskets and the same bore I could have determined how much the 2 were in cc's and used that for a better gauge. Yes No maybe?
#95 |
Liked 372 Times in 129 Posts
#96 | |
#97 |
#98 |
Correct, the Oldsmobile cylinder head is an inline design with a 6 degree valve angle. Completely different to a Chevy head with a 23 degree valve angle.
#99 |
Liked 17 Times in 14 Posts
Sounds like it will be the "Wheeler dealer Wagon" Good Luck, I'll keep following your progress.
Dave Outten 2222 S/SS/SST/SG/HR 2021 S 1968 SS 1969 SR 1966 1990 Bracket |
#100 |
Great name for this project as I have been trading, ebaying, swap meeting parts for this project. Just bought complete new front steering components and a-arm bushings as the originals are shot $111.00. The third head was warped .020 and was not worth cutting as I was sure it would be to small after CC'ing. Fourth head was only .004 warped and after clean up it cc'd correct. Total $3666.50
