Old 01-21-2019, 01:36 PM   #91
Billy Nees
Liked 7,783 Times in 1,743 Posts
Default Re: Fly Weights
ok,
Iron Duke late 1960`s? I recall a 68 or 69 Nova w/4 banger, and a guy called it an Iron Duke.
The Iron Duke popped up in the late 70s and lasted through the 80s. They had some similarities to the Chevy II engine but I don't think there was much in the way of parts interchange.
The Chevy II 4s were used by Mercury Marine for a very long time. I know they survived into the 1990s and maybe later.
Billy Nees 1188 STK, SS
Old 01-21-2019, 02:41 PM   #92
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
How about a 1982 Camaro with a 151ci Iron Duke 90HP / 120 NHRA HP
U/S or U/SA at 2570#
OR
SS/PA or SS/P at 120 NHRA HP and 2210# min weight...
Too bad that the Quad-4 never came in a rear wheel application, I think?????
That was a very trick engine…..
Bob Mulry 7516 STK
A & M Motorsports
Old 01-21-2019, 05:37 PM   #93
Weren't those used in marine applications a lot?
Also in Mail Jeeps. That's the source of the Chevy pattern 904's ,later used in Comp.
The story is they would have been real dogs, fully loaded, with a PG.
Old 01-21-2019, 06:40 PM   #94
G Schenck
Liked 81 Times in 35 Posts
Friend of mine's father bought three old mail jeeps for his pest control business. I drove one at Southland Dragway in Houma around 1974. If I remember it ran 24 seconds with the sliding door opening on the leave.
Greg
G Schenck is offline   Reply With Quote
Old 01-21-2019, 07:09 PM   #95
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
The Iron duke was used in various cars when I worked as a line mechanic in the mid to late 70’s. It had both intake and exhaust ports on one side of the head around 1976 and was changed the following year to intake on one side and exhaust on the other side. Many engines from all manufacturers were used in industrial applications long after they were discontinued in vehicles. The iron duke was one used a lot to power generators as well as marine engines. It had a very long life in various configurations!
Rich Biebel
S/C 1479
Stock 147R
Old 03-21-2020, 06:57 PM   #96
Billy Nees
maybe just one more.
Old 03-21-2020, 07:06 PM   #97
bykr
Liked 167 Times in 81 Posts
How do guys with late model Fords deal with that variable venture carb?
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 03-21-2020, 09:14 PM   #98
Ah ! Billy and I have talked about that one.
Nobody has had to use one with a 302 yet.. It might come to that, eventually.
Take a look down through one, with the throttle plates and the top flapper open, and let us know what you see ;-)
Old 03-21-2020, 09:41 PM   #99
Mike Schwartz
Liked 248 Times in 89 Posts
How about one of the 68-74 Opels in the Guide? A 1971 Opel 2-dr sedan or wagon with the 115/75 2bbl L-4 has a minimum weight with driver in T of 1880lbs. It can go as low as 1790lbs in R.
Old 03-21-2020, 10:13 PM   #100
Mike Graham
Liked 341 Times in 67 Posts
Are you sure?
Mike Graham is offline   Reply With Quote
