Old 10-06-2024, 06:30 PM   #11
CMcAllister
Liked 797 Times in 225 Posts
Default Re: Rear gear question
My handy dream wheel says 133 is 10 flat horse power, 600 - 620 HP or so.
1.45 60' isn't hateful. Probably has mid 1.30 in it anyhow. A 3 speed, with the extra SLR should make it 60' a little better. A lightweight 3 speed would be even better.
Depends on your goals. More rear gear, as was said, will help. Agree with a 5800 converter. Beyond that, if it's consistency on marginal tracks, you're probably best with that low gear. Want to go fast, need the low gear a 3 speed would offer. And more tire.
Old 10-06-2024, 07:16 PM   #12
Adger Smith
Liked 798 Times in 297 Posts
Need a neutral or negative converter to get it to pull off line & the gear change.
5800 stall OK, but there is more to the converter than stall speed.
I agree with tire and rear gear change.
1.96 low might wake it up too, but shift it at higher RPM with a lower low gear PG.
You are carrying quite a lot of weight for a 7.38 starting line ratio...2.52 low gear 3 speed puts the SLR at around 10.33. With the right 3 speed converter it would pick up a bunch. Probably on the + side of .15..
Adger Smith (Former SS)
Old 10-06-2024, 07:31 PM   #13
Adger Smith
oops!
Old 10-07-2024, 11:45 AM   #14
Lenny5160_v2
Lenny5160_v2's Avatar
Liked 196 Times in 80 Posts
I have to think the converter is real tight.
My Nova is 3600#, 1.80 glide, 4.10 gear, 28" tire and has 660 HP. I can't go 133; 128 is about the best it'll do but it's usually a 1.40 60'.
So, same running gear setup but heavier and less power.
Tony Leonard
S/C & S/ST 5160
Lenny5160_v2 is offline   Reply With Quote
Old 10-07-2024, 12:25 PM   #15
1320racer
1320racer's Avatar
Liked 583 Times in 287 Posts
or heads are too big
Old 10-07-2024, 07:29 PM   #16
CMcAllister
or cam
Old 10-07-2024, 07:45 PM   #17
Stan Weiss
Stan Weiss's Avatar
Liked 611 Times in 333 Posts
3400# car, 28" tire, 739 HP, Auto trans
I would want to see somewhere around an 11.5 SLR
NOTE this is ONLY a recommendation for what might be a good STARTING POINT
Stan
Old 10-07-2024, 09:57 PM   #18
L.Fite
Liked 401 Times in 204 Posts
5.14 and a 3 speed might get him there...
L.Fite is offline   Reply With Quote
Old 10-08-2024, 08:04 AM   #19
Stan Weiss
Stan Weiss's Avatar
A 2.74:1 first gear 3 speed and his present 4.1:1 would give him a 11.234 SLR. Not a bad starting point.
Stan
Old 10-08-2024, 09:07 AM   #20
1320racer
1320racer's Avatar
SLR is internet forum bs like dynamic compression ratio.
My SLR is 8.748, what am I doing wrong?
Meanwhile, I have a data recorder, download every pass and KNOW at what RPM exactly my converter flashes to and falls back to on the gear change as well what RPM I'm shifting at and crossing the stripe at in addition to all the other data I record and plot every pass.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
