09-09-2024, 09:09 AM | #31 |
Liked 91 Times in 39 Posts
Re: Fine them and then make it legal. Wowwser
I thought they had the correct pulleys, but the positions were reversed. Big pulley on the jackshaft and small pulley on the blower and it would spin faster.
09-09-2024, 09:57 AM | #32 |
Liked 58 Times in 28 Posts
that is what I was thinking reading between the lines.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
09-09-2024, 10:10 AM | #33 | |
Liked 132 Times in 31 Posts
FX L177, FSS 3 STK L177 Lenny Lottig |
09-09-2024, 11:00 AM | #34 |
Liked 448 Times in 74 Posts
The rules don’t apply to certain people. I’m pretty sure they aren’t the only classes they have “bent” the rules in over the years. They seem to be untouchable when it comes to tech, tear down, etc!
09-09-2024, 11:40 AM | #36 |
Liked 437 Times in 71 Posts
Sad at this development all the carnage and drama to fx and fss while this went on. People made decisions based on being down horsepower and losing. Shame on Nhra tech as counting teeth on a pulley, a space on a pulley, even if no teeth are there, should be counted if you didn?t pick up the increased diameter by eye.
How do the Stanfields look their fellow racers in the eyes from here out. This isnt a misinterpretation of the rules. Would be with 2 black eyes if I were in those classes wasting my time and $$$ |
09-09-2024, 11:41 AM | #37 |
Liked 588 Times in 289 Posts
09-09-2024, 01:22 PM | #38 |
Liked 304 Times in 163 Posts
Since multiple offenders were in on the scheme perhaps NHRA should mandate that ONLY NHRA STAMPED AND SERIAL NUMBERED APPROVED pulleys may be used. ALL pulleys must be registered as to serial number. The serial number and NHRA logo must be easily readable. Makes no difference on what make of engine being used or the type/brand of supercharger ONLY an accepted pulley is legal. No modifications of any type whatsoever to the pulley can be done WITHOUT NHRA written approval. If the pulley is modified from the OEM specs NHRA will have to approve the modification. NHRA will further keep a record of ALL pulleys and serial numbers as well as who owns them. If the owner/driver/engine builder no longer has the pulley in their possession( car/engine is sold)or the pulley is damaged beyond repair then the pulley MUST be re-registered to the new owner BEFORE it can be used in NHRA competition. Pulleys MUST BE used in the ORIGINAL position that they were designed for such as a lower must be used as a lower an upper must be used as an upper NO SWITCHING positions ALLOWED
IF YOU GET CAUGHT USING ANY PULLEY OTHER THAN A NHRA SERIAL NUMBERED AND REGISTERED PULLEY, the results are : FIRST OFFENSE: Automatic 1 year suspension for the driver and/or the car owner, $10,000 fine payable immediately , forfeiture of all points , all illegal parts will be immediately confiscated. If they are dumb enough to commit a second offense LIFETIME BAN for the driver and the car owner in NHRA activities plus a $25,000 fine payable immediately. Do you think this might stop it??? FED 387 Last edited by FED 387; 09-09-2024 at 01:27 PM. |
09-09-2024, 01:22 PM | #39 |
Liked 1,734 Times in 405 Posts
As it has been said before
Don?t ask for permission Ask for forgiveness They knew better than to ask. Grey area REALLY!
james perrone 1290 STK |
09-09-2024, 07:49 PM | #40 |
Liked 2 Times in 1 Post
As a fan from Down Under I find it difficult to believe a few things.
1. The NHRA didn't specify the OD of the pulleys (as well as tooth count) to ensure this didn't happen. (Or the temptation there to explore a grey area of the rules) I am sure there are other classes with toothed belts that have explored this in the past and NHRA would have closed the loophole? 2. Specify the pulleys had to be marked and manufactured by Magnuson, or have an NHRA approval number on it. 3. Inspect these critical components after every pass with fuel and weight, considering it is a 10 second job to measure the OD with a Vernier and count the teeth to see if there is any distinctive gaps between the teeth. 4. Question why covers had been put over the rear drive belt (covers were mentioned in this thread earlier) as the cover is there to hide something and not protect the driver when there is a windscreen and firewall between the driver and the pulleys. This has tarnished my view of racers and engine builders that I look up to in the /FS, /FX world as I have built my GM car using the /FS rules as inspiration. |
