Old 05-06-2024, 12:46 PM   #1
Mike Savelle
Liked 7 Times in 5 Posts
Smile burn out box
when doing the burn out car goes side ways, made 4 pass in both lane and the same every time 30 x 9 Hoosier. CO 6., new car first time out. help please . Mike
Mike Savelle is offline   Reply With Quote
Old 05-06-2024, 01:08 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,948 Times in 589 Posts
Default Re: burn out box
Rear end out of square. Broken Axle. one front brake not holding. Preload in the suspension are all things to look for.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 05-06-2024, 01:11 PM   #3
Mike Savelle
Smile Re: burn out box
thanks. I'll check out of square and preload, every thing else is brand new.
Old 05-06-2024, 01:17 PM   #4
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Could be.
Could also be the water box guy is no good or you’re pulling too far out of the water assuming you have a spool and not a posi,
Old 05-06-2024, 01:25 PM   #5
Mike Savelle
Yes spool, 9" tire stocker. thanks , I think it was the water mans first day. !
Old 05-06-2024, 03:24 PM   #6
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: burn out box
Tire guys are usually pretty good about matching pairs but it wouldn't hurt to check the circumference on both slicks.
LOCOMOTION Racing
Old 05-06-2024, 05:04 PM   #7
J.R. Haddad
Liked 1,471 Times in 308 Posts
Pre-Load.
J.R.
J.R. Haddad is offline   Reply With Quote
Old 05-06-2024, 05:41 PM   #8
Jeff Stout
Liked 706 Times in 283 Posts
Square up rear end or preload
Old 05-07-2024, 05:38 AM   #9
Henrys Toy
Liked 520 Times in 176 Posts
Good morning Mike and to all,
I had that happen to me at the second Maple Grove race in 2023, I also had a one year old Hurst Line Lock solenoid go bad me as well.
I tried another line lock solenoid form a friend and that's been working OK again. "New" doesn't seem to mean anything anymore. Good doesn't also.
You might be going through some New Car "Bugs", silly stuff that just needs a tweak or two and then you'll be on your way. Good luck on your adventure. You have to go race the car in order to find the problems.
Have a Good Day.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 05-08-2024, 09:05 AM   #10
1320racer
1320racer's Avatar
This says all I need to know and supports what I have stated previously. Too many track owners/managers fail to understand that the water box guy(s) are the most important staff member on the track to those that are actually racing, it is not an entry level position.
