Old 05-14-2008, 04:18 PM   #1
Dave Goob Cook
Dave Goob Cook's Avatar
Default Re: Question about Loctite?
why is it $25-30 a bottle ?
Because a bottle taken care of will last you 15-20 years.
What I want to know is how you can get the lid off, if the stuff works?
Dave Goob Cook is offline   Reply With Quote
Old 05-15-2008, 12:39 AM   #2
Adger Smith
Liked 880 Times in 311 Posts
Dave,
If a bottle last you 15 to 20 years then you aren't using it as much as I do in my shop. Send your old Loctite to me & I'll cycle it into use.
Art,
I use the red on flywheel bolts on my odd fire V-6 and blue on the Converter bolts. I use an L-9 bolt on the converter with fine thread poly lock nuts. Get ready to tighten things regularly. The harmonics of these non V-8 engines cause nuts & bolts & other parts to fall off. We re check the converter & tranny bolts & drive line every 3 passes. Motor plate & mid plate is another area that gets the same P/M schedule on the bolts. Using wrenches regularly is just the price we pay for running these combinations. Good luck...
Art, another thing to remember is to use a shouldered bolt. A long shoulder that goes into the flywheel & part way into the converter boss. You know the way Std. shift flywheels hold clutch covers on, in alignment. That helps to minimize the shear on the bolt by spreading out the load.
Adger Smith (Former SS)
Old 05-15-2008, 12:48 PM   #3
mtkawboy
Liked 54 Times in 18 Posts
They have it as a paste in a tube now so you dont have to worry about knocking the bottle over and losing $25
mtkawboy is offline   Reply With Quote
