Liked 13 Times in 7 Posts
Guys,
I'm looking for suggestions on how to create low drag brakes. I have Wilwood 4 piston caliper brakes front & rear on my Gen 3 GT/DA 92 Camaro. Is there a kit one can buy? The TDM brakes are out of the question. Thanks for looking, |
Liked 2,469 Times in 695 Posts
I shim the caliber with spacer to make sure they are centered
on the disc properly (usually they are not). They still have more drag than the more expensive brands that my son runs on his cars!
Liked 126 Times in 61 Posts
As well as making sure the caliper is center I have small stiff springs I put between the pads so the cotter pin holds the springs in place.
Liked 759 Times in 379 Posts
Liked 7,913 Times in 1,515 Posts
Or Lamb brakes ….There are always budget minded racers that will take the Wilwood’s off your hands ,,..Lamb brakes = $$ well spent ….
![]() ![]() Last edited by MR DERBY CITY; 11-25-2023 at 10:48 AM. |
there's good reason why you won't find wilwood brakes installed on any car built for drag racing by a professional chassis shop
Liked 71 Times in 38 Posts
Doesn’t Wilwood offer a low drag “ o†ring to replace the square cut seals in the calipers?
Liked 13 Times in 11 Posts
Making sure the calipers are centered is a no brainer , but switching to drilled rotors was the best thing I did. No more drag. This and the right pads.
Mine are Wilwood. |
