Old 11-12-2021, 02:14 AM   #1
mtwilly
Liked 4 Times in 1 Post
Default Re: 1995 Firebird Suspension Help
Originally Posted by countrypuppy4865 View Post
Tubular nonadjustable lower control arms. Frame reinforcement kit from S&W and a good anti roll bar is all you should need. Stock springs work fine if it sits too high you can remove the upper rubber from the spring. All of the stockers you see have weight in the rear. Afco shocks from Fastshocks for the front are most critical. Even stock gas back shocks work fine as long as they are in good shape.
One more question... by 'frame reinforcement kit' do you mean subframe connectors? Thank you!
mtwilly is offline   Reply With Quote
Old 11-15-2021, 12:13 AM   #2
mtwilly
One more thing... The only tubular nonadjustable LCAs that I find have poly bushings. Is this ok, or do I need solid bushings? Thanks, again!
Old 11-09-2021, 12:05 AM   #3
mtwilly
Originally Posted by Ralph A Powell View Post
Contact FJ Smith @ SPS 905-772-5535
He has built a lot of Firebird Stockers.
Will do. Thank you!
