Old 07-02-2020, 10:20 PM   #1
monte385
Liked 27 Times in 19 Posts
Default Re: changing q-jet secondary rods
Anybody try different sizes of sec. air bleeds?
monte385 is offline   Reply With Quote
Old 07-02-2020, 11:15 PM   #2
Dissident
Liked 73 Times in 36 Posts
Yes. Changing air bleeds in both primary and secondary is a sensible way to fine tune one of these organized leaks. Of course there are those that do not believe that is necessary and think that jets and rods are the only way to make adjustments. The things were designed around trying to pinch down on emissions and do so cheaply.
Regards to All that like this kind of stuff,
HB2
Dissident
Dissident is offline   Reply With Quote
Old 07-03-2020, 07:47 AM   #3
Alan Nyhus
Liked 800 Times in 237 Posts
Yes. The air bleeds/emulsion tubes are very important. -Al
"That'll never work....."
Old 06-23-2020, 07:53 PM   #4
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
Originally Posted by Dissident View Post
Mr Nyhus and Others that might be interested in some facts from measurements,
1) Most 750 type QJs flow test to be from a very poor low of 164cfm to an average of 170-175cfm at 20.4"H2O test pressure.
2) Most 750 type QJs flow test at 660cfm to 675cfm on the secondaries at the same test pressure as above.
3) Doing some quick math to see how much that is in mass flow of air in lbs/hr at sea level, yields 798 lbs/hr on Primaries and 2622 lbs/hr on Secondaries.
4) Allowing for max power at somewhere near 12.5:1 A/F ratio would yield fuel use on primaries of 63.84lbs/hr (127.68Hp) and 209.76lbs fuel use on secondaries (419.52Hp) supplying a total of 547.2Hp
As you can see, that is 23.33% fuel on primary and 76.67% on the secondary. IF one sees that the primary is supplying the 40% as claimed in the quote, one can only assume the secondaries are not at WOT or something is categorically wrong with the carburetor or the fuel supply system tune.
Hope that helps.....No, I do not have a race car but have supplied assistance to make more than a few more than competitive.
Regards,
HB2
Dissident
Harold,
Just a question about the BSFC you used. Is that what a competitive engine will show or did you just choice it for ease of Math? Never seen a dyno sheet from a competitive S or SS engine.
Stan
Old 06-23-2020, 10:27 PM   #5
Dissident
Stan,
Thanx for the question.
In the example I used here, I just used a BSFC of 0.5lb/hp-hr which is a pretty good target for planning. However, it is quite common for BSFCs to be somewhere around 0.45 to 0.47 when everything is complimentary. Stockers have to use OEM manifolds and SS stuff uses other than OEM so they can get a bit more fuel efficient as happens when CR go up as well. I did not get into an analysis of efficiency, simply wanted to point out the fallacy of following the wrong guidelines on how the goofy QJ works in practice. These things are more fun than a box of puppies when tweaking them on the dynamometer.
Regards,
HB2
Dissident
