Old 03-30-2020, 11:14 PM   #1
cmracing
Liked 62 Times in 29 Posts
Default Re: Factory efi
One thing is something I was doing with my old Jr Stock ‘56. Running more timing in low & second gear. Something Jere Stahl put me onto over twenty years ago. I now run different timing in each gear. Easy 5 hundredths there. Jere told me he and Bill Jenkins had done that for years. Used to do it with our old dual point distributors & a toggle switch. “Turn on” the second set of points to retard the timing. I had re-drilled the breaker plate in my ‘56 Corvette distributor to move that one set of points to adjust the amount of retard. Spent most of a day on my Sun “distributor machine” working that deal out. Had the toggle switch mounted where my Hurst shifter tripped it going to high gear. I was much younger then, could usually remember to flip the switch back on the return road. LOL My FAST ECU does it all for me now. I do have a toggle switch now that shuts that function off, to help slow the car down when I don’t need it. The FAST XFI ECU can hold 5 “tunes”, I just use two.
You can do this with the Holley also. If you want to have multiple tunes inside the ECM to switch between you need the Dominator ECM. There is so much that can be done with the Holley that people just don't even know about.
cmracing is offline   Reply With Quote
Old 03-30-2020, 11:53 AM   #2
Jeff Niceswanger
Liked 1,072 Times in 379 Posts
I have tuned several with both FAST XFI & Holley. I would certainly disagree. I can & do make the FAST system do things the Holley can not. Besides the Holley ECU failures I have seen.
Most, in fact just about all the issues with the Holley is installation, and piss poor map set up. Actually its amazing how bad they can be and still run half way decent. Had a guy come over to our pits last summer and wanted me to look over his stuff. He said it ran fine, didn't miss or bog or anything, but the engine builder kept telling him he thought it should be faster. He says its a seven under car, he's happy with that, but lets have a look at it ..First thing I noticed was his data log showed crazy things going on with his TPS signal. And the better I adjusted the fuel map (which was a mess) the worse the signal got. I contacted Robin and he tells me a few areas to look at. Turns out, the units main voltage inputs did not go directly to the Battery. It was not set to the right parameters in the crank trigger settings. And the tune needed alot of work. We were both amazed when the car picked up THREE tenths. One solid tenth in 60 foot. Holleys are killer units, I think they have over 35 thousand of them out in service ( Right Robin?), but GIGO, Garbage In, Garbage Out, is absolutely the thing to watch on them....
Jeff Niceswanger 3740 SS
