Old 11-14-2019, 09:36 AM   #1
Lee Valentine
Liked 319 Times in 68 Posts
Default Re: What Stock rules would you change?
True start.
Lee Valentine 1661 STK
Old 11-14-2019, 09:43 AM   #2
TILBURG
Liked 79 Times in 7 Posts
Do away with the whole ring spacer get up. Might need steel spacer in your diesel pistons but a unnecessary expense on a stocker. Roller lifters isn't going to make anyone notice a increase in there wealth either.
TILBURG is offline   Reply With Quote
Old 11-14-2019, 10:08 AM   #3
Mike Ours
Cool Re: What Stock rules would you change?
personal indexes.....: if you spend like a comp car might as well race like one...
Mike Ours is offline   Reply With Quote
Old 11-14-2019, 11:32 AM   #4
Liked 5,151 Times in 1,966 Posts
Roll bar rule, by ET..Just like Joe Bracket Bomber...11.49 and faster
Old 11-14-2019, 02:00 PM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Limit valve spring pressure. Maybe 120lbs seat, 300 lbs @ .500".
Old 11-14-2019, 03:00 PM   #6
Alan Nyhus
Liked 800 Times in 237 Posts
Moving a front mounted battery to the trunk is a no brainer, simply from a safety stand point. -Al
"That'll never work....."
Old 11-14-2019, 04:01 PM   #7
Bruce Fulper
Liked 54 Times in 33 Posts
Maybe tear down #1 qualifiers when they're goofy fast?
Bruce Fulper is offline   Reply With Quote
Old 11-14-2019, 04:27 PM   #8
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Best request yet ! I tried to get NHRA to set spring pressures at 150 lbs and 350 lbs open back in 1985. That's the same as a 426 street Hemi and a 440 6 pack if I remember right. It was like talking to a wall !
Old 11-14-2019, 04:35 PM   #9
Mike Mans
Liked 299 Times in 48 Posts
Well that's an interesting idea. Do you really need much more seat pressure than this? Seems kind of wasteful on a lot of friction based valvetrain motors to run so much spring pressure...
Mike Mans is offline   Reply With Quote
Old 11-17-2019, 03:08 AM   #10
Todd Hoven
Guest
Posts: n/a
Pontiac had dual valve springs from the factory in some combos that had more open pressure then that. Just saying
