Old 07-15-2019, 02:34 PM   #1
HR9121
HR9121's Avatar
Default Re: Horsepower on tuesday
Something happened, he's on the sheet then he's off and then back on it. Don't add up, someone knows something out there and if they don't stand up and say something that's as bad as doing it yourself.
I'm pretty sure I wouldn't be able to get away with what's been said happened but difference is I wouldn't do it in the first place, I got integrity.....
James Williamson
W200 J/SA. SS/JA
Old 07-15-2019, 02:16 PM   #2
jmdavison
jmdavison's Avatar
Liked 16 Times in 6 Posts
Cool Re: Horsepower on tuesday
Originally Posted by B Parker View Post
I really don't have a dog in this fight except my brother has my old Corvette and runs the same class. Different year and engine parts. If someone makes a time shot and they are light going across the scales not matter what they went for a time the run should not count. We see it all the time. Someone DQ'd at the bottom of the list on their first time run. So if you go across the scales light even though you went 1.20 or more why should it count. What if someone wanted to ruin a combo. Drop 200 lbs out of the car go 1.30 under. When you cross the scale should that run count. Now the difference here is some of you are saying he played with weight at the top end before going across the scales. Did any of you see it? Did anyone from NHRA see it? If not run should not count. If someone intentional plays with weight after a run at the top end before they hit the scales and an NHRA official see's it different story. Be careful wishing someone to get HP it could be your combo next. BP
The rule book says You must scale or fuel ck,(Sec 2 P 11) if you run quicker than any previous run. If cody made a mistake by running to quick, step up and take the hit. Just sayin,,,,
Jeff Davison
6047 Stk/SS
jmdavison is offline   Reply With Quote
