Old 05-16-2019, 09:40 AM   #1
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Default Re: Locked out distributor advance question
Originally Posted by Bruce Fulper View Post
Between all of the allowable tolerances of the cam and dist. gear and the rubber band up front, (timing chain) you'll never remove all of the slop. But don't worry about it. When it's floored its tightened up.
Agreed, when I said no more movement I meant in the centrifugal advance mechanism itself. There was no noticeable change in the gear clearance, and I didn't add to the shims.
Dave Muller is offline   Reply With Quote
Old 05-16-2019, 12:13 PM   #2
Liked 5,134 Times in 1,958 Posts
Back in the 70's, GM sold a pack of distributor shims. They were .010 or .015 maybe ?
Ten to a pack , and it would take about half of them to shim up a distributor gear to remove most of the play there.
Always wondered why they left them that loose . GM must have seen as a hi-po issue, or they wouldn't have sold them.
I wonder if they are still available or somebody has them as NOS ?
