Old 07-01-2018, 11:20 PM   #471
Dave Gantz
Liked 226 Times in 118 Posts
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Nmbr1GMfan View Post
Thank you, very helpful
I agree, good stuff.
Old 07-01-2018, 11:27 PM   #472
Dave Gantz
Sounds like great service, I have another one that's almost new, I could use it and send this one back.
Yeah, now you have a spare.
You guys are gonna have a nice car. Can't hurt to take a breather. Making a car right isn't easy.
Autumn, you are learning a LOT.
Todd, this thread is showing what's involved in building a nice car. I would venture to guess that most casual onlookers will learn a lot from your well very documented experience.
Old 07-02-2018, 09:02 AM   #473
Nmbr1GMfan
Liked 1,957 Times in 492 Posts
Thank you. As always it takes longer that you'd like to get one done, we're just changing so much that it adds tons of time. One word of caution to everyone, it's challenging to build something that you can't find parts for.
Todd Greene
Old 07-03-2018, 03:35 PM   #474
Bob Mulry
Bob Mulry's Avatar
Liked 321 Times in 101 Posts
Just my two cents......
You might consider upgrading with an Adapt-A-Cap from MSD.
This type cap increases the spacing between the spark plugs contacts inside the cap and helps prevent misfires..
While you are at it drill a 7/16 hole in the cap midway between #1 spark plug and the coil terminal to correct the rotor phasing.
Make sure you get the set with the adjustable rotor to correct phasing after you time it.
Have fun...
Bob Mulry 7516 STK
A & M Motorsports
Old 07-04-2018, 01:12 PM   #475
6130
Liked 117 Times in 50 Posts
Stock drum brakes in the back? What brakes are you using up front?
Old 07-05-2018, 08:18 AM   #476
Nmbr1GMfan
Have fun...
Thanks Bob.
Todd Greene
Old 07-05-2018, 08:22 AM   #477
Nmbr1GMfan
It has strange fronts, I thought about putting a set of discs on the rear but just not sure if it's necessary.
Todd Greene
Old 07-07-2018, 01:58 PM   #478
6130
It may be necessary in a heads-up race...
Old 07-07-2018, 10:45 PM   #479
Nmbr1GMfan
Anyone have any real performance advantage data from the brake swap weight savings?
Todd Greene
Old 07-08-2018, 12:45 AM   #480
pfordamx
Liked 7 Times in 5 Posts
we just recently swapped from drum to aerospace rear disk on our amx weight savings was 30lbs total about 20 of which was rotating i can't give any real performance data we changed engines too part of the winter upgrades. But that's roughly the weight savings.
pfordamx is offline   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
