Old 11-10-2018, 04:14 PM   #1
NSSGTO
NSSGTO's Avatar
Liked 24 Times in 17 Posts
Default Re: Hercules 225/75r15 12 Ply
Giving this a little bump as I will be swapping out my 2 year old Westlakes around Feb 19. Anyone else running these yet?
NSSGTO is offline   Reply With Quote
Old 11-19-2018, 08:22 AM   #2
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
Originally Posted by lareagle View Post
Has anyone ever used a heavy ply truck tire in place of the trailer tires ?
Tire dealer said the speed rating is about 65 mph on trailer tire and were
running right on edge that could make to much heat on tire.
Larry
I recently switched to 10 ply truck tires after having blow outs with 10 ply trailer tires.
The trailer pulls so much better now.
I had to go to 16 inch wheels to use the LT225-75-16 Truck tires.
LT truck tires are the way to go, IMO.
Anyways, my trailer uses 5 lug 4 1/2" bolt pattern.
I was amazed to only find one wheel company that made a 16 inch- 5 lug 4 1/2 inch bolt pattern wheel in steel.
Old 11-21-2018, 10:45 PM   #3
copo69
Where did you find the 16 inch wheels with the 5x4.5 bolt pattern?
copo69 is offline   Reply With Quote
Old 09-30-2019, 03:38 PM   #4
Glenn Briglio
Glenn Briglio's Avatar
Liked 969 Times in 307 Posts
Any updates from using these Hercules trailer tires 15"
Glenn Briglio is online now   Reply With Quote
Old 10-20-2019, 10:40 PM   #5
NSSGTO
NSSGTO's Avatar
I have been running these all year. Only have around 5-6K on them but so far so good. They really track better than any other trailer tire I have used.
I run around 90PSI in them, They are on a 28FT ATC with 3500lb car, golf cart, tools etc weighing in around 9800.
