HOME MAGAZINE FORUM RULES SPONSORS CONTACT
Old 01-29-2018, 08:50 PM   #1
Mark Ruset
Default Fuel Pressure
Looking for feedback on fuel pressure settings with a 327 and a Quadrajet for stock and what differences you may have seen running a higher number for et and mph.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 01-30-2018, 07:55 AM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 14 Times in 8 Posts
Default Re: Fuel Pressure
I have a super stock car with that combo. I run 6 lbs of fuel pressure. 8600 rpm in the lights at 130 mph. Volume is more important than pressure. You need at least a gallon of fuel in 30 seconds or less at the carb.
Mike Pearson 2485 SS
Old 01-30-2018, 08:19 AM   #3
Jim Kaekel
Liked 8 Times in 2 Posts
Agreed. Unfortunately, a Q-Jet has only one needle and seat.
Jim Kaekel 3836 STK
Jim Kaekel is online now   Reply With Quote
Old 01-30-2018, 08:33 AM   #4
Alan Nyhus
Liked 7 Times in 4 Posts
Mark, I run that exact combination...no difference from 5 1/2 to 7 lbs. Mine will vary about half a pound depending on the fuel. Adequate volume is the key. A bypass regulator or a pump that can bypass can help stabilize the fuel pressure and keeps the fuel cooler. -Al
"That'll never work....."
Old 01-30-2018, 08:07 PM   #5
Mark Ruset
thanks to all who replied, I use a BG 280 with #12 line from the fuel cell to the pump #10 line to the regulator and #8 line from the regulator to the carb. My question was, does fuel pressure say set at 6 , 6 1/2 or 7 psi have any effect. And how much fuel pressure can the needle and seat withstand.
Mark Ruset 2048 STK
Old 01-31-2018, 12:27 AM   #6
GTX JOHN
Liked 9 Times in 8 Posts
The higher the pressure goes the more strain on the needles and seats to do their job! I run 6 1/2 lbs. on my Quads and Thermo.
I have run 8 lbs. without a noticeable difference in performance if jetting is in the ballpark.......
But it triples my needle and seat issues!
John Irving
741 Stock
741 Super Stock
Old 01-31-2018, 09:55 AM   #7
jims5600
Many years ago when I was racing,I found thru GM parts a needle and
seat that was used for motorhomes. We put that on a tow vehicle and
it cured some issues for us. Don't know if that is still available but it
would be something to think about.
jims5600 is online now   Reply With Quote
Old 02-01-2018, 09:41 AM   #8
nhramnl
Liked 9 Times in 4 Posts
Dean Oliver may respond on his own (if he sees this string), but he helped me overcome a problem I had with richness and smoke at idle and low speeds (e.g. driving around the pits). I checked and rechecked everything with my Q-Jet 305, including even fiddling around with various fuel pressure settings, and the problem would not go away. I called Dean and almost the first question he asked was "Which needle and seat is in the carb"? I told him it's the extra-super-big one that Edelbrock sells, and he told me to remove it and go to the next size smaller. His explanation was that there is so much fuel flow through the big Edelbrock needle and seat that the incoming fuel actually partially overcomes the ability of the needle to close completely, which functionally raises the float level and causes flooding. He also said that with any "normal" racing fuel pressure, the fuel enters the bowl so violently that it keeps the fuel in the bowl all "stirred-up". I changed to the smaller needle and seat and the condition is gone.
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.Ad Management plugin by RedTyger
