Old 06-05-2017, 08:00 PM   #1
richie 2
Liked 205 Times in 93 Posts
Default Hardblock?
I have a set of S/S 350ci chevy pistons + .060''....should I hardblock fill my 010 block to support that large an oversize? wondering about the extra weight too...tks.
Old 06-05-2017, 08:34 PM   #2
Tim H
Tim H's Avatar
Liked 484 Times in 160 Posts
Default Re: Hardblock?
Most replies are going to favor the hardblock procedure.
Tim H is online now   Reply With Quote
Old 06-05-2017, 09:12 PM   #3
HP HUNTER
Liked 373 Times in 129 Posts
Yes
HP HUNTER is online now   Reply With Quote
Old 06-05-2017, 09:17 PM   #4
Absolutely. In fact, you should probably have it thoroughly sonic tested. The majority of those blocks are really marginal at that over size.
Old 06-05-2017, 11:15 PM   #5
richie 2
alan even if its thin, would the filler not still support it? so the thicker the better...fill the thickest one?
Old 06-06-2017, 05:47 AM   #6
carl hinkson
Liked 18 Times in 10 Posts
Sonic test first and at that bore plate honing is a must to achieve good ring seal.
Personally i don't find many OEM blocks that would be a good build at .060 over. Like I said sonic test first.
carl hinkson is offline   Reply With Quote
Old 06-06-2017, 12:06 PM   #7
James L Miller
Liked 25 Times in 16 Posts
Do you use a half fill or a full fill? Do you put a gasket and head on after filling that side of the block so the bores are distorted in the same way as when running? I was thinking of buying the full fill Hard-Blok and then using half in my 273 Mopar block (and 1/2 of that on each side). I've never used this before, but the cylinder walls on the 273 blocks are under .200" thick, some down around .130" with a standard bore. The cylinder walls tend to be thinner in the middle and the front and rear areas between the cylinders.
Mopar 2 Ya!
Old 06-06-2017, 04:22 PM   #8
GTX JOHN
Liked 2,493 Times in 700 Posts
.130 at Std. Bore is rather thin.
Might be worth checking a few more blocks.
If that is on thrust side I personally would not like to us that block.
Suggest filling it to within a inch or 1 1/2 to top of water passage if
I did use it.
John Irving
741 Stock
741 Super Stock
GTX JOHN is online now   Reply With Quote
Old 06-07-2017, 10:13 AM   #9
randy wilson
Liked 22 Times in 22 Posts
Do what you want, but I wouldn't hard block anything. Did a 0.060 over 283, and a 0.030 327, and if you could watch the shaking of the stones when rehoning after teardown, versus ones being honed without any hardblock, you'd know what I mean. They never, ever, stayed round. And everything was done with two torqueplates, mains, and pump installed. I have never used it since.
don,t have one
Old 06-07-2017, 11:04 AM   #10
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
If you had the choice , wouldn't it be better to start with a good block , like a Bowtie or Dart ? A filled block has other problems like bores going out of round , or cooling problems when racing . What does a filled block weigh , compared to a Bowtie block . Plus after you where it out for bore size , it can be sold to someone that can use a bigger bore size . In the long run it might not really cost more to run a good block .
