Liked 213 Times in 85 Posts
Whats the average rule of conv. slippage = in RPM +/- ? I'm trying to see what the top end RPM is with different rear gear ratio's .... RPM x tire dia. / by MPH X 336 = ring & pinion ratio . That formula dosen't account for conv. slippage , and is giving me the wrong gear ratios ....The car goes thru at 6750 x 28 tire / average 115 mph x 336 = 4:85 gear . But thats not true because it runs a 4:30 not a 4:85 . What would it go though with 4
:56 like 7150 rpm in average air ? My math / formula is wrong or I'm missing some thing . |
Liked 239 Times in 114 Posts
Also if you have bias ply slicks you get some tire growth . Radials not so much .
Liked 2,467 Times in 695 Posts
Hard to put a number on slippage from this little info.....Converters vary
greatly. MY best advise is just trial and error if you do not have a Data Monitoring System to fall back on.
#4 | |
115 x 4.30 x 336 / 28 = 5934 RPM (drive shaft RPM) 5934 x 100 = 593400 / 6750 = 87.9% (or 12.09% slippage) 115 x 4.56 x 336 / 28 = 6293 (drive shaft RPM) 6290 / .879 = 7159 RPM The 4.56 gear should let the converter show better efficiency but, no way of knowing exactly how much. Like was already stated, tire growth will affect the final number. |
Liked 681 Times in 203 Posts
5% slippage is a good number to shoot for.
Liked 5 Times in 5 Posts
What if your % is 112?
you are slipping 12 %
Converter too loose????
I would have to double check but I think there is about a 1200 RPM drop between gear change(PG) Last edited by jaf2021; 04-15-2017 at 09:14 AM. |
Liked 5,109 Times in 1,947 Posts
Ken, Ever try a 4.10 with that converter?
I have not tried the 410 gear yet . I need to try the lower 1st gear before I try the 410 . Its a low rpm torque combo mainly so I see your point Mark . Thanks
