Liked 320 Times in 102 Posts
Hi,
The rule had always been.......... Nothing through the firewall...... I don't think that it would change because a cage was the car..... A K/SA can run a cage if desired...... Just making Stock into Super Stock and Super Stock into Comp.... Bob
Liked 204 Times in 54 Posts
"FIREWALL
"Alterations prohibited unless expressly permitted in this section. Firewall coverings prohibited.Where heater/air conditioning units have been removed, area must be covered with minimum .024-inch steel or .032- inch aluminum, including rear hood seal/flange, as on GM A-body. Minor firewall modifications permitted to C5 and C6 Corvettes for transmission installation. Roll cage tubing may run across top or side of inner fender well/strut tower and attach to frame horn. " The last sentence has never been made clear (at least not to my knowledge). Does it apply to the corvettes or all stocker? |
