Thanks for your input Ed I appreciate it. But you have me a bit confused on what you said about my shock setting. I'll admit that I'm new to the whole adjustable shock deal and I'm learning as I go. My understanding was that if I wanted to soften the hit on the slick I should soften the shock. Is this incorrect? I had the shocks set to the tightest setting with the radials and a much higher launch rpm at Norwalk a few weeks ago and the car worked great. Then without changing anything I took the car to my local track and the car spun badly at the hit. Doing what I thought was correct I softened the shocks and took out 800 rpm from the launch and it was better but still spun. What am I missing? Am I going about it totally wrong?
#2 | |
I've been at 21psi..but I haven't tried anything different in the heat. I was pretty sure I didn't want to go lower and was afraid to go much higher. I'll try 22psi tonight at test and tune.
Liked 431 Times in 224 Posts
I wouldn't run a bias slick if they paid me to.
I run Hoosier 9" radials on a 10" wheel. Burnout is extremely minimal. I do not use a line lock. Low gear just to get them spinning, then shift to high. Weight in the trunk is definitely good. I think I have a couple hundred pounds back there. I run 17 psi but, honestly, it is only for even wear with my combo. I've been from 16 - 26 and have never seen a difference in performance. Half the time I don't even check them once I've made a couple passes. It did take some work initially once I got some decent HP. You'll want to make sure the front end moves freely. I've never counted passes, but I'm sure I get 150 on the Hoosier C07 tire. Stick with them and you will be better for it! I love hearing others complain about a tricky track. As long as I don't go up in smoke, I know my 60' time will be within .01 of the previous run.
S/ST 51 S/C 53 |
On my 3500 pound H stocker chevelle I am lucky to get 40 passes on a set of M/T Radials, they hook great just not long lasting.
Dion Hildebrandt 6009 STK H/SA |
