Go Back   CLASS RACER FORUM > Class Racer Tech > Garage Tech
Old 07-14-2019, 03:07 PM   #1
Stick cars rule
Stick cars rule's Avatar
Default Re: New concrete shop floor coating recommendations
im sure ken has finished his floor by now and hope it worked out good.as a concrete polisher I thought I would share my thoughts.preping floor with acid does not do much.grinding thru the cap is a must.not only does it smooth the floor,the coating will penetrate for a strong bond. also using densifiers before a coating will effect the bond. I offer grinding services for diy home owners.look for a concrete polisher in your area for prep, it will be worth it.
Scott justo.
2009018 lc22r
Stick cars rule is offline   Reply With Quote
Old 05-22-2017, 07:20 AM   #2
Brandon Davis
Originally Posted by SGSST109E View Post
Sherman Williams has some good products. A concrete stain. Its a available in tints or just clear. It is solvent based. I rolled it on, it gets tacky very quickly. Gas, oil etc. doesn't effect it even after days. Tires won't pull it up. Makes cleaning up so much nicer. MY garage is 30' x 30'. New concrete floor just swept it clean before. MAchine floated floor that was very smooth.
I have been doing a lot of research on this topic, I am very interested in this product...Is it the H&C color top solvent based solid color concrete sealer? How does it do resisting chipping, like from jack stands? How long have you had it down now? Did you have to clear over the stain?
Thanks
Brandon
Brandon Davis is offline   Reply With Quote
