Old 12-04-2015, 01:34 PM   #1
Grey Ghost
Grey Ghost's Avatar
Liked 210 Times in 88 Posts
Default Re: 3sp to 4sp manual
I want to update from the Mopar electronic race ignition to an MSD. What is the difference between the 6AL and the 6AL-2. Both have 2 step and listed output is simular. Both are suppose to work with the Mopar distributor. Anyone have a preference.
Grey Ghost is offline   Reply With Quote
Old 12-07-2015, 11:04 PM   #2
T Ames
T Ames's Avatar
Liked 125 Times in 33 Posts
Hello Phil. The 6AL provides an allowance for the addition of a two step while the 6AL-2 has the two step built in. I use the 6AL with a two step module along with a Mopar distributor. It works fine. I'd opt for the unit with a built in two step though if starting from scratch.
T Ames is offline   Reply With Quote
Old 12-08-2015, 01:18 PM   #3
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Phil,
I just spoke to Bob Blackwell our D5 tech director, and you will need to submit this for a rule change. Bob did not have to think very long before he answered, so it is a no. It's not a big deal to get the ball rolling to at least get this reviewed. I pointed out the clarification on the auto trans so that is your ringer. Why can an auto car that came with a 2 speed run a 3 speed, but a stick car that came with a 3 speed not be able to use a readily available 4 speed? The sooner you get something submitted the better off you will be.
The first G-Force I bought was from Jim Voth, it was a 5 speed as I am allowed to run one, but Jim could not, so he had removed the gear for 5th to be legal. It was another neutral, I do not remember if he did anything with the shifter as that was not part of the purchase. So you will be stuck with something like that, but worse and some not very ideal gear ratio combinations with a 3 speed.
I hope I did not muddy the water for you.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 12-08-2015, 02:22 PM   #4
Adger Smith
Liked 880 Times in 311 Posts
At one time I think there was an allowance for a car that was offered with overdrive.
Like, the three speed with overdrive option is allowed a 4 speed.
Or was it just talked about?
I think Dwight or someone that still has a memory.might be able to help my memory on that one.
Adger Smith (Former SS)
