Liked 20 Times in 15 Posts
I was just weighting a set of rods [I beam small journal 327 SBC], reconed by the machine shop. all are within 1/2 a gram except one which is 2 grams light. [has to be on the big end, cause the small end has nothing to loose].
what is the acceptable +/- spread? thanks Rod in AZ |
#2 | |
Liked 18 Times in 10 Posts
That being said I see alot of the GM crate circle track engines and have seen rods per set off as much as 8 grams and those engine run for years with zero problems and look very good when disassembled. You should be fine. |
Liked 263 Times in 68 Posts
Two grams is the weight of 2 $1.00 bills.
John Dinkel 3295 STK |
Liked 880 Times in 311 Posts
If you are not swinging the rods and weighing from end to end you are killing time. Assuming a set is equal on each end, big are equal as well as small ends, is a pretty big assumption. I've run into sets that are as far off as 7 or 8 grams. I think that is about the + or - for auto makers tolerance. Read a good tutorial about balancing before you start grinding on anything.
I bought my first balancer in 1977 and there is no telling how many mismatched components I've seen. If the rods were at one time a balanced set the resizing probably did take a couple of grams off the big ends.That happens on every set that is resized and all you can do is equalize them to the lightest one. Or if you want to cut the amount of change of the bob weight in half.... match a heavy rod with a lite one to make a pair.
Adger Smith (Former SS) Last edited by Adger Smith; 06-22-2015 at 03:46 AM. Reason: sp |
the small/little end has been computer cut, there is no extra material. all small ends weigh the same. the big end pads are all there is to cut.
so I assume that 2 grams is within normal race tolerance. thanks Rod in AZ |
Not at my shop. 1/2 gram is the number for me. If you are not re balancing the crank that will put you in an over balance situation on the bob weight If you are talking about a total change of 2 to 4 from where the rod was when it was first balanced it will be ok. The big end is a X 2 multiplier on the bob weight calculations.
Adger Smith (Former SS) |
