Old 06-01-2015, 09:37 AM   #21
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Default Re: Broken Torque Converter
Can someone tell me if a 200 and a 200r4 stator support is the same and is it just a bolt in part?? Thanks I think we hurt something in our car this weekend and acts the same as above -- will not leave and last week was pulling tires 2 feet in the air.
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 06-01-2015, 09:43 AM   #22
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
They are not the same. 200 has a support that is an integral casting to the pump cover, and the 200-4R has a press fit and bolted in support. The spline is the same though.
ss3011 is online now   Reply With Quote
Old 06-01-2015, 12:00 PM   #23
Daran, Call Leo at Remac in San Dimas. He can probably get you fixed up.
Old 06-01-2015, 12:05 PM   #24
Greg, If the converter is that old, it could probably use springs and rollers in the sprag anyway.
Could be chewed up and not holding well.
I would say you ought to eliminate that variable at this point.
Old 06-01-2015, 02:18 PM   #25
Eric Merryfield
Eric Merryfield's Avatar
Liked 503 Times in 131 Posts
Smile Re: Broken Torque Converter
Originally Posted by Greg Gay View Post
Mark,
The engine in the car is a 400 Chrysler. For the last 15 years, I ran the car (80 Dodge Mirada) with a 318 engine. But now, I have the 400 in it. Just to see if the carb was the problem, I put the 318 carb (small T-Quad) on the 400 for one run, but the car acted similar, only slower. I apologize for not making that clear.
Thanks,
Greg
P.S. The torque converter currently in the car is old. Came with the car. I would say it is 20 years old, but has been setting for 15 years. The trans is a brand new Pro Trans. Less than 30 runs.
Could you put a stick in it Greg? No more convertor drama.....Might want to keep that protrans for the Superbee,or is it a road runner, I get them confused. Eric
Eric Merryfield 1883 STK
Old 06-01-2015, 09:58 PM   #26
Greg Gay
Liked 286 Times in 73 Posts
O.K., it finally sunk into my tiny pea brain this morning that while the stator is in the torque converter, the stator SUPPORT is in the transmission. Therefore, it is conceivable that the change of converter possibly wouldn't fix the problem. I do now have a new converter ordered. What is involved in changing the stator support? If it is broken, will I see it?
Eric, I'd love to drive a stick car. I just don't know that I want to MAINTAIN one. The Stocker is a Super Bee. The bracket car is a Road Runner, but I don't think you've seen that.
Greg Gay is offline   Reply With Quote
Old 06-02-2015, 12:18 AM   #27
jmantle
Liked 172 Times in 81 Posts
If the stator support is not obviously broken, try turning it with a big pair of channellock pliers. If it won' turn, it's not broken. Assuming you have a 727 in the car, I've never seen a 727 stator support break or spin out.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 06-02-2015, 08:11 AM   #28
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Originally Posted by Eric Merryfield View Post
Could you put a stick in it Greg? No more convertor drama..... Eric
Here, here!! Give that man a beer!
Old 06-02-2015, 01:26 PM   #29
Rod Greene
Liked 242 Times in 81 Posts
The myth of a stick car is just that. With the modern clutches and trans maintenance is minimal. I see more guys covered in auto trans fluid cussing their convertors or sprags than any stick shift guy. But with the herd mentality most guys run autos.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 06-02-2015, 08:41 PM   #30
Greg Gay
It's even worse than that, Rod. I have an electric shifter!
Seriously, I would like to drive a stick. Even though the transmissions are much more reliable, due to the fact that you set the clutches up so softly today, I thought the slippage required continual adjustment. I will say "Someday, maybe."
