Old 10-23-2014, 12:18 PM   #1
7423
Default Re: Fox and SN95 Mustang rear control arms
Originally Posted by HandOverFist View Post
By adjustable I meant the spring perches, not in length. Would these be legal? Are you guys using a sway bar on the rear?
Probably not a good idea. Visions of a very narrow minded tech inspector in a bad mood signing your card in red ink instead of black. The rulebook does use the term non adjustable. The jury is out on the factory sway. Not real sure if it is of any value. I have always used the factory bar and have no experience without one.
7423 is offline   Reply With Quote
Old 10-23-2014, 12:40 PM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
How about a set of adjustable lowers once set then welded up solid? No longer adjustable, right? I'm always digging... I've noticed that most of the aftermarket lowers are still using poly bushings instead of solids.
Rich Taylor
I/SA - 321
